Re: 340 engine balance question.
[Re: fastmark]
#1554864
12/29/13 02:18 AM
12/29/13 02:18 AM
RapidRobert
All I can add is that (drilled hole vs no hole) is alot of grams of material difference & it is in the rotating part of the eng rather than the reciprocating part which means that weight difference is doubled in the bobweight formula for it's actual affect on eng balancing. EDIT You could measure the dia/length of the hole then google the weight of steel then figure the amount (volume) of material that would have been in the hole for a close approximation on how many grams difference there is.
[Re: fastmark]
#1554866
12/29/13 08:00 PM
12/29/13 08:00 PM
RapidRobert
You could take that 318 crank in & see what it balances to (how many grams) then go to work on weighing your rods/rod bearings etc to see what piston weight you need. HF has a gram scale for $15 & it's on sale regularly for $10. You can rig up a fixture to hold your rods horizontle to weigh the big/small ends. rods can be lightened on the balance pad & some on the small end & deburring the shank on the sides. Pistons can be lightened slightly. BB pins can be shortened 1/4" on each end with no durability issues as the pins are too big to start with. Teh bobweight formula is online & is simple. You may be close as is & this'll tell you if you can get by with or without a lighter piston and with or without rebalancing.
