Re: Suggestions on ignition tuning a 472 HEMI: Billet Dist?
[Re: DaveRS23]
#1554332
12/27/13 10:37 PM
12/27/13 10:37 PM
808CUDA
Thanks for the inputs. I just fumbled through my Larry Sheppard book on HEMI's and seen it is recommending 28 total. My first Hemi so I'm learning here. I'm use to the typical 34 total on big blocks. Thoughts on the 28? My pinging does not occur during WOT. Only while applying throttle aggressively on a higher gear (i.e. Third gear and about 2-3k rpm). So far no bad words about the distributor I have
[Re: RapidRobert]
#1554333
12/27/13 10:42 PM
12/27/13 10:42 PM
808CUDA
I'd set the initial with the "vac gauge method" then adj the total (initial+slots) to what the std is for Hemis then mix/match springs till you are just under the pinging point at WOT up thru the gears on your hottest/driest (most likely to ping) day. IN ORDER. You'd want the mixture somewhat close then timing first then get mixture (jetting etc) dead on
Thanks Rob! I've been so away from carbs I'm starting to forget a bit finding the initial it likes by watching best idle response then adding the additional advance in slots. Glad I have 650 AVS' so tuning secondaries should be easier. My first time working with 1:1 linkage too.
[Re: 808CUDA]
#1554334
12/27/13 11:18 PM
12/27/13 11:18 PM
RapidRobert
With the "vac gauge method" you keep advancing the initial timeing till the manifold vac on the gauge stops advancing then back off the timing till the vac number drops 1 in hg & this is your ideal initial that YOUR eng likes/wants. If the starter balks when hot then reduce the initial (not the in hg) another 1 degree & retest & maybe reduce another 1 degree or instead of reducing it more than the initial 1 degree which you ALWAYS do you might try an ign bypass & crank it then switch on the ign while it's cranking if you want it tuned to the nth degree & dont want to compromise the timing just for the starter. When finding the "initial" all the while you are advancing the timing you keep slowing the idle speed back to what your lowest hot in gear idle speed is which is what you will see at the stoplight. Also you want the springs to start advancing no less than ~200 RPM above this hot idle speed number
