Page 1 of 3 1 2 3
62 Polara 500 Cruiser #1554264
12/27/13 06:56 PM
12/27/13 06:56 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
So this car "was" to be the basis for a clone of a 62 Polara I had in HS in the 60's. I bought it sight unseen off ebay in SF. The pics below are on arrival are #1-3. OEM, all Polara's had a 361/4bbl and Alum 727's. This car, according the plethora of receipts that came with it, looked to be owned by a Coors executive in Spokane. He restored it in 1980, and as best I can tell, he replaced motor/trans with a rebuilt slightly warmed over 273/4spd, I assume because this was the middle of the second "gas crisis". This helped in making the car less desirable on ebay, and I didn't care, since I was planning on dropping in a 440+ with long rams. However when I got the car and drove it, plans changed, the 273 was pretty peppy and the car was rather nice, even with the crushed velour interior . So this is just upgrading it into a nice cruiser.
Re: 62 Polara 500 Cruiser [Re: jcc] #1554265
12/27/13 06:57 PM
12/27/13 06:57 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
2 The wheels are AR 14x8 200S Coke bottles, not my favorite, but I'll keep them as long as they make 245/50's, unfortunately it limits rotor sizes.
Re: 62 Polara 500 Cruiser [Re: jcc] #1554266
12/27/13 06:57 PM
12/27/13 06:57 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
3 Transport damaged, thought to be as bought but seller said 100% NOT ugh!!!
Re: 62 Polara 500 Cruiser [Re: jcc] #1554267
12/27/13 06:58 PM
12/27/13 06:58 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Re: 62 Polara 500 Cruiser [Re: jcc] #1554268
12/27/13 06:59 PM
12/27/13 06:59 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
5 Just reminiscing, this is my original custom hood from 1967.
Re: 62 Polara 500 Cruiser [Re: jcc] #1554269
12/27/13 06:59 PM
12/27/13 06:59 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Re: 62 Polara 500 Cruiser [Re: jcc] #1554270
12/27/13 07:00 PM
12/27/13 07:00 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
7 Period correct wheel? Soon to be replaced by a new one.
Re: 62 Polara 500 Cruiser [Re: jcc] #1554271
12/27/13 07:01 PM
12/27/13 07:01 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
8 Connector primary flange layout, with center weld hole
Re: 62 Polara 500 Cruiser [Re: jcc] #1554272
12/27/13 07:02 PM
12/27/13 07:02 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
9 Welded 2x2 connector, not thru the floor
Re: 62 Polara 500 Cruiser [Re: jcc] #1554273
12/27/13 07:03 PM
12/27/13 07:03 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
10
Re: 62 Polara 500 Cruiser [Re: jcc] #1554274
12/27/13 07:04 PM
12/27/13 07:04 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
11 This was our second set of Flex A Form fiberglass springs, strangely they failed as crack/split indicates, they replaced without hesitation, replacement set was made wrong, likely am using Hyperco only in the future
Re: 62 Polara 500 Cruiser [Re: jcc] #1554275
12/27/13 07:04 PM
12/27/13 07:04 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
12 Crushed velour? Installing rear seat belts
Re: 62 Polara 500 Cruiser [Re: jcc] #1554276
12/27/13 07:05 PM
12/27/13 07:05 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
13 Rear seat belt tie down
Re: 62 Polara 500 Cruiser [Re: jcc] #1554277
12/27/13 07:06 PM
12/27/13 07:06 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
14 One Comp cammed robust 273 with 4 sp out for a little spicing up
Re: 62 Polara 500 Cruiser [Re: jcc] #1554278
12/27/13 07:06 PM
12/27/13 07:06 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
14.2
Re: 62 Polara 500 Cruiser [Re: jcc] #1554279
12/27/13 07:08 PM
12/27/13 07:08 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
14.5 I believe the safety loop moves forward with the Passon tranny and losing the slip joint
Re: 62 Polara 500 Cruiser [Re: jcc] #1554280
12/27/13 07:09 PM
12/27/13 07:09 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
15
Re: 62 Polara 500 Cruiser [Re: jcc] #1554281
12/27/13 07:10 PM
12/27/13 07:10 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
16 If I remember correctly thats a slant six sized 9"? Disc, good for road race?
Re: 62 Polara 500 Cruiser [Re: jcc] #1554282
12/27/13 07:11 PM
12/27/13 07:11 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
17 New Alum Passon Jamie rocks
Re: 62 Polara 500 Cruiser [Re: jcc] #1554283
12/27/13 07:12 PM
12/27/13 07:12 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
18
Page 1 of 3 1 2 3
