I've got an Edelbrock LD4B intake and an Edelbrock 1406 600cfm carburetor that I want to install on my 1971 Dart Swinger with a 318 and console shifted A904.
I know the 2-bbl "kickdown linkage" will not work with the 4-bbl. I understand the "kickdown linkage"
MUST be installed to prevent transmission damage.
I was hoping to find all the Lokar parts necessary to perform the 2-bbl to 4-bbl swap. Lokar's website is not real clear.
Has anyone used Lokar "throttle" and "kickdown linkage" components? If so, can you share the Lokar part number(s) necessary for the swap?
Thanks to all for your help!
