Re: Are E-body strut rods suppose to be bent at the end? [Re: moparmarks] #1551671
12/25/13 11:39 PM
12/25/13 11:39 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Here is what I am talking about.
Careful, your character's showing!
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551672
12/25/13 11:44 PM
12/25/13 11:44 PM
The one on the bottom is severely fubared & the one on the top less so. After all the yeas & nays on this what is your verdict
Re: Are E-body strut rods suppose to be bent at the end? [Re: RapidRobert] #1551673
12/25/13 11:49 PM
12/25/13 11:49 PM
mopar346 Offline OP
mopar346  Offline OP
Replacement is in order. Is a 71 and up B body the same? I have one and access to several more.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551674
12/26/13 12:10 AM
12/26/13 12:10 AM
I ain't sure as I am almost exclusively into A bodys but we did race an E body one time
Re: Are E-body strut rods suppose to be bent at the end? [Re: RapidRobert] #1551675
12/26/13 02:47 AM
12/26/13 02:47 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Both of those puppies are bent.
66-72B and 70-4E are the same. All others are different.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Are E-body strut rods suppose to be bent at the end? [Re: moparmarks] #1551676
12/26/13 11:40 AM
12/26/13 11:40 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you Mark, I have a slew of those, probably even some that aren't bent.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551677
12/26/13 12:13 PM
12/26/13 12:13 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Ouch, Those are both bent. The top one might be straightenable. The bottom, toss it.
Astrobuf
So, are you really a Rocket Scientist?
Re: Are E-body strut rods suppose to be bent at the end? [Re: astrobuf] #1551678
12/26/13 04:50 PM
12/26/13 04:50 PM
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551679
12/26/13 10:35 PM
12/26/13 10:35 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Replace them. These are from a 70 E-body.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #2330042
07/02/17 01:27 AM
07/02/17 01:27 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 B Body
Ordered the H D Mancini Strut Rods
You can see the one in the picture ( Top) next to my factory strut rods
You can also see the factory strut rods have a dog leg bend in both rods , in the exact same location
K Frame has been powder coated and straight as an arrow perfect
Lower control arms , new bushings and straight as an arrow
Make a long story short
These Mancini Strut Rods will not fit , not even close
My factory strut rods are about 17.5" from shoulder to shoulder
Mancini is 18" - Obviously these Mancini Rods are sweet , but no way they will fit , even with no inside bushing let alone the Moog bushings or Energy suspension bushings that I have
What am I missing here ???
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Are E-body strut rods suppose to be bent at the end? [Re: jcc] #2330178
07/02/17 01:43 PM
07/02/17 01:43 PM
Originally Posted By jcc
All the tow truck drivers I asked say yes, and if they aren't they will be glad to fix them for you.
Ding ding ding I do believe we have a winna.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #2330185
07/02/17 02:05 PM
07/02/17 02:05 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
These are going back to Mancini
Bottom line , they don't and won't fit and if I could some how , my alignment would bee fffffffffffffff ed , they are to long
Others , same issue over on ForBbodiesonly , with pictures installed
Sounds like I need to find some originals or adjustable s
Siberian Huskies
Re: Are E-body strut rods suppose to be bent at the end? [Re: bee1971] #2330200
07/02/17 02:44 PM
07/02/17 02:44 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I haven't read the entire thread recently, why again are you replacing the "bent" ones? They are FWIW only loaded heavily during braking, and that is in tension, ie, that tries to straighten out the bend. Any attempt to bench straighten them, would only improve matters, visually, and reduce any possible lengthening as the bend straightens under braking. twocents
edit, before we obsess on the bend straightening issues, my guess is the OEM rubber bushing solution by itself used on millions of mopars, allows 1/4"? of movement (which is a lot more then your pictured bend could possibly contribute) in hard/daily use, and really hasn't been a concern. Its a minor issue on anything that is not on the track IMO.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #2330213
07/02/17 03:34 PM
07/02/17 03:34 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Because everyone on the internet says they must bee straight , however I have worked on more then a few 71 72 B bodies that have had these exact same configuration
Anyways , like I said , Mancini s are to long shoulder to shoulder , and that's a fact
Siberian Huskies
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #2330225
07/02/17 04:16 PM
07/02/17 04:16 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I got a RUST FREE set at Spring Fling for $30 and they had all the hdw and were perfect. That was this year. Very easy to find a set.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #2330496
07/03/17 02:14 AM
07/03/17 02:14 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Wait a sec. I thought this was about E- bodies??? Why does the Mancini part say B-body?
