Are E-body strut rods suppose to be bent at the end? #1551651
12/22/13 07:26 PM
12/22/13 07:26 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Both of mine a bent slightly at the K-member end, but they are even so I am wondering if they were bent that way on purpose or are they suppose to be perfectly straight like A-body ones?
If they should be straight what other ones will interchange correctly?
It is an AAR if that matters.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551652
12/22/13 07:55 PM
12/22/13 07:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
They're all bent slightly like you describe.
Sheldon
Re: Are E-body strut rods suppose to be bent at the end? [Re: RUNCHARGER] #1551653
12/22/13 08:54 PM
12/22/13 08:54 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I ain't never did notice that on my AAR & I rebuilt the front end myself. News to me.
Re: Are E-body strut rods suppose to be bent at the end? [Re: Sunroofcuda] #1551654
12/22/13 09:24 PM
12/22/13 09:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If they were supposed to be bent, there would be a up and down to them.
If it's a really tiny bend that you can only see on the bench or only by measuring them, I don't think it will make any difference. Especially with rubber bushings.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551655
12/22/13 09:30 PM
12/22/13 09:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Need a picture to know what your talking about.
Most are slightly bent from service and can be bent back slightly with a press, no big deal.
Re: Are E-body strut rods suppose to be bent at the end? [Re: Challenger 1] #1551656
12/23/13 12:45 AM
12/23/13 12:45 AM
mopar346 Offline OP
mopar346  Offline OP
I'll lay them out tomorrow and see if I can get a good picture of them. I did grab a set of A-body one I have sitting in the shop and they are straight as an arrow, just shorter (that's how I know they are A-body).
Thanks for the info so far.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551657
12/23/13 01:25 AM
12/23/13 01:25 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Swing over to Bill's website: http://www.bmcuda.com/
He has a restored set on his homepage.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551658
12/23/13 01:33 AM
12/23/13 01:33 AM
Yes absolutely
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551659
12/23/13 01:54 AM
12/23/13 01:54 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
They are supposed be straight, just like the A body ones you have.
If both sides are bent equally, it may have been a half azzed attempt of introducing extra positive caster into the alignment. Put a jack under the strut, crank it up, it bends and shortens the effective length, you are adding positive caster by default. Swapping back to straight struts will subtract positive caster.
Re: Are E-body strut rods suppose to be bent at the end? [Re: TC@HP2] #1551660
12/23/13 02:42 AM
12/23/13 02:42 AM
IN
ahy Offline
ahy  Offline
IN
Its fairly common for the strut rods to have a "dog leg". My OE rods do. Some have more than others. With the dog leg the working ends are still in line... in between though, there is the dog leg. If the rod is bent by hooking a chain or wrecker, ends are no longer in line.
Re: Are E-body strut rods suppose to be bent at the end? [Re: ahy] #1551661
12/23/13 12:25 PM
12/23/13 12:25 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I have a frontend i took out of a 72 charger and the strut rods were bent on it both look the same was looking at the ones under the gran coupe were working on there stright
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551662
12/24/13 01:55 PM
12/24/13 01:55 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
All the tow truck drivers I asked say yes, and if they aren't they will be glad to fix them for you.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551663
12/24/13 03:31 PM
12/24/13 03:31 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Even my 71 B body rods were bent. Probably to clear the sway bar assay making assay easer.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551664
12/24/13 04:36 PM
12/24/13 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's my thinking: If the strut was supposed to be bent, the FSM would make mention of which way to clock it on installation....it doesn't, the FSM merely says to install the strut and torque the nuts.
Re: Are E-body strut rods suppose to be bent at the end? [Re: John_Kunkel] #1551665
12/24/13 05:57 PM
12/24/13 05:57 PM
MN
astrobuf Offline
astrobuf  Offline
MN
My observation is that the E Body strut rods are not bent, they just kinda look like it because of how they were machined.
The Rod's appear to be a forging and are not really "round". The threaded ends appear to be "offset" from the center of the rod which makes them look bent. In fact, in my case, the threaded ends are straight with each other, but the rods look funny as the thread center is offset from the rod center.
Astrobuf
So, are you really a Rocket Scientist?
Re: Are E-body strut rods suppose to be bent at the end? [Re: John_Kunkel] #1551666
12/24/13 07:18 PM
12/24/13 07:18 PM
BDW Offline
BDW  Offline
Here's my thinking: If the strut was supposed to be bent, the FSM would make mention of which way to clock it on installation....it doesn't, the FSM merely says to install the strut and toque the nuts.
I agree, and if they were bent the travel wouldn't be symmetric.
The stock ones I replaced were bent, the new ones from Just Supensions were not.
Re: Are E-body strut rods suppose to be bent at the end? [Re: BDW] #1551667
12/24/13 10:40 PM
12/24/13 10:40 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks for the info so far. I am convinced at this point that they are bent, I may try to straighten them but if I can to my satisfaction then I will replace them. What other car do they interchange with if any? I have a number of cars that I can borrow them from if I have a match.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551668
12/25/13 01:36 AM
12/25/13 01:36 AM
IN
ahy Offline
ahy  Offline
IN
I've got a set of OE rods from a 70E. They do have some "dogleg" but I believe ends are straight. PM me if you need them.
Re: Are E-body strut rods suppose to be bent at the end? [Re: mopar346] #1551669
12/25/13 01:40 AM
12/25/13 01:40 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have bent plenty of them, they were all straight to begin with...
JB Rhinehart, Realist
A-Body's RULE!
Re: Are E-body strut rods suppose to be bent at the end? [Re: Rhinodart] #1551670
12/25/13 10:54 AM
12/25/13 10:54 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have several sets and they are straight. Bent ones go in the scape pile.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
