Re: B & M Shifter Cable Routing any ideas. [Re: 67coronetman] #1551162
12/23/13 11:42 PM
12/23/13 11:42 PM
MNobody Offline
MNobody  Offline
I went to a 4 foot cable after i burned up the one that came with the shifter for my 69 charger, the length is perfect routed like he said
Re: B & M Shifter Cable Routing any ideas. [Re: 67coronetman] #1551163
12/24/13 02:46 AM
12/24/13 02:46 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Did you happen to have a shorter cable or the one that comes with it originaly
I use a B&M Quicksilver in my 67 Satellite. Cable comes through the floor, forward above the starter, then I route it between the starter and the block. This keeps it tight to the tranny, and away from the exhaust. Exits below the starter and runs straight back to the shift arm on the tranny.
I've had it like this for years without a problem. The only time I have burned a cable was a few years back, but that happened when I tried to route the cable a different way with zip ties and such. Went back to the between the starter and block path when I replaced it.
Nope. Thats with the stock length cable that comes in the box.
Re: B & M Shifter Cable Routing any ideas. [Re: StealthWedge67] #1551164
12/24/13 08:10 AM
12/24/13 08:10 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
After burning 3 cables I routed it over the intake.
No problems no since 3 years. Might be easier with other cars,
but that ws the only good route for my c-body with headers.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: B & M Shifter Cable Routing any ideas. [Re: Den300] #1551165
12/24/13 11:38 AM
12/24/13 11:38 AM
Maryville tn
67coronetman Offline OP
Maryville tn
Wow very interesting.. But it works and that is what really matters.. Thanks for showing & sharing.
Old car are me......
Re: B & M Shifter Cable Routing any ideas. [Re: 67coronetman] #1551166
12/24/13 11:52 AM
12/24/13 11:52 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I burnt up two on my 57 truck. The second one even had the heat wrap on it. I finally went with a Lokar. The only downside to a Lokar is you don't have any "lockout" between gears.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: B & M Shifter Cable Routing any ideas. [Re: MNobody] #1551167
12/24/13 12:41 PM
12/24/13 12:41 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I just went through this about a month ago though on a different application, W2 small block A body, 904. The header tubes are larger on the W2 TTis so they create some clearance issues.
The shifter comes with the 5 foot Super Duty cable and it was laying right on the number 5 tube. Went to a 4 foot regular duty cable (less sheathing material) and it worked perfectly. Nowhere near any heat. The regular duty is a little more flexible which helps with routing. A 3 foot cable would have been too short.
Like some suggested above, I tried to route it around the right side with the 5 foot but the angle of the cable where it attaches to the pan bracket was too severe and it was causing binding.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: B & M Shifter Cable Routing any ideas. [Re: 67coronetman] #1551168
12/24/13 01:49 PM
12/24/13 01:49 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have had a couple of PMs asking for more info on routing the cable from the rear. This is the best photo I can come up with, although I am not sure if there is enough detail.
This works real well in my Dart.
Master, again and still
