Page 2 of 4 1 2 3 4
Re: what can be done to a 360 for strength [Re: BJS racing] #1546735
12/13/13 01:08 AM
12/13/13 01:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The biggest problem with the small block mopars are the main webs between the cam and the crank. They are not strong enough to support much over 600 - 650 HP. you will find people out there that have made more power than that and had no problems and some that haven't even made that much and had big problems. Main cap walk and the block its self are the biggest issues. A good main cap system (pro-grams) or something similar with studs and a good balance job are highly suggested.
I'm surprised at your findings. I've seen these problems with B/B but never a small block. I've never seen a small block pull a main web out like a B/B? Any pics? Split cylinder wall possibly.
We've run boosted ones for years with no failures, Yet.
Doug
Re: what can be done to a 360 for strength [Re: dvw] #1546736
12/13/13 01:21 AM
12/13/13 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All I have done is split cyl walls... I have blown
one up due to ripping a Viper rod in half.. they arent
as strong as they said LOL.... never had any cap walk
Re: what can be done to a 360 for strength [Re: ] #1546737
12/13/13 02:17 AM
12/13/13 02:17 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
it will be getting head studs and cometics.
Re: what can be done to a 360 for strength [Re: mopar dave] #1546738
12/13/13 02:37 AM
12/13/13 02:37 AM
Moparts
SSDart Offline
SSDart  Offline
Moparts
I just skimmed thru this thread........
Fill the block
Radius the edges in the main bores and the cam bearing bores
Light pistons of course........ mine are just over 400grams
Cometic gaskets if your running over 13 to 1
Girdles...... Ford guys like them.... can't actually see how they can help on a ford let alone a much stronger SBM..........
...... The over lap on the 360 crank does contribute to it's strength ...... But at the ned of the day they are just plane beefy cranks.... Don't be afraid to take the journals down in size........ Smaller is safer..
Re: what can be done to a 360 for strength [Re: SSDart] #1546739
12/13/13 03:07 AM
12/13/13 03:07 AM
Mt Morris Michigan
Mt Morris Michigan
what size jounal would you recommend and how is smaller safer?
Re: what can be done to a 360 for strength [Re: mopar dave] #1546740
12/13/13 03:31 AM
12/13/13 03:31 AM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Taking the journals down to 2" and using a chevy end connecting rod would be ideal..... the smaller journal has less surface speed plus think you can grind the crank with a generous radius making it much stronger again........... cost effective?? I'm not sure...
Re: what can be done to a 360 for strength [Re: MR_P_BODY] #1546741
12/13/13 03:33 AM
12/13/13 03:33 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
You seem to have good package there, sounds very angry. I'm suprised it's not a little quicker. What does the car weigh ? and did that enormous carb pick the car's Performance up ? What is your pb ?
Mick
My cam is all wrong... it should be a FAIR bit quicker
but thats gonna be for someone else since I'm sellingg
the car... I cant get a NHRA license any more...
its been 8.96.... should be closer to 8.60 and the
new cam should do it
why can't you get a NHRA license anymore
Re: what can be done to a 360 for strength [Re: SSDart] #1546742
12/13/13 11:36 AM
12/13/13 11:36 AM
Mt Morris Michigan
Mt Morris Michigan
I haven't seen much of a selection of the 2" journal rods. who has them?
Re: what can be done to a 360 for strength [Re: RAY1969CARS] #1546743
12/13/13 11:41 AM
12/13/13 11:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mick
Health reasons
Re: what can be done to a 360 for strength [Re: MR_P_BODY] #1546744
12/13/13 11:50 AM
12/13/13 11:50 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Mick
Health reasons im so sorry bro !
Re: what can be done to a 360 for strength [Re: MR_P_BODY] #1546745
12/13/13 12:27 PM
12/13/13 12:27 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Lightest rotating weight possible and keep the RPMs down.
Re: what can be done to a 360 for strength [Re: TheOtherDodge] #1546746
12/13/13 01:43 PM
12/13/13 01:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
No offence Mike but my comments were meant for the OP. Lol
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what can be done to a 360 for strength [Re: mopar dave] #1546747
12/13/13 02:07 PM
12/13/13 02:07 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Use ARP or stock head bolts. Use head studs and you will blow head gaskets. If you insist on head studs, turn the dia. between the threads down to 7/16" and they will work. Cometic gaskets and 13.5 to 1 will work fine. The eng. in my Demon has 1800+ passes and still the same head gaskets, with 13 to 1 CR. Stock block, no fill and center 3 caps are Pro-gram 2-bolt caps. Crank and pistons have never been removed from the 1973 360 block, for all 1800+ passes. Car runs high 9s and a best of 9.68, on 110 oct. gas, at 3050 lbs. with a crank trigger and 28* timing. Also a flat tappet cam and production cast iron cyl. heads. Build a good sm. block and you will never need to switch to a big block.
Re: what can be done to a 360 for strength [Re: mopar dave] #1546748
12/13/13 02:56 PM
12/13/13 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW I know someone goin low 9`s n/a w/a cast crank..............
Re: what can be done to a 360 for strength [Re: qwkmopardan] #1546749
12/13/13 02:59 PM
12/13/13 02:59 PM
Mt Morris Michigan
Mt Morris Michigan
haven't heard that before. I thought head studs created a better clamping force to help prevent head gasket blow out? i'm currently using the ARP head bolts. guess I could reuse these and save alittle.
Re: what can be done to a 360 for strength [Re: qwkmopardan] #1546750
12/13/13 03:04 PM
12/13/13 03:04 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'd like to hear some logic behind that one. It flies in the face of common top engine builders best practices throughout the country.
Also, in my opinion a lot of the reason yours has lasted a long time is the fact that it's only got 28 degree's of timing in it.
Cylinder pressure early in the cycle puts an enormus stress on parts (and worse yet if it's detonating.) Remember if it's got a lot of cylinder pressure at TDC (or near it), it's trying harder to push the crank out the bottom of the block then it is trying to turn it!
Re: what can be done to a 360 for strength [Re: dizuster] #1546751
12/13/13 03:07 PM
12/13/13 03:07 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
All I want to know is how long does it take to put 1800+ passes on an engine. Wholly crap.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: what can be done to a 360 for strength [Re: mopar dave] #1546752
12/13/13 03:16 PM
12/13/13 03:16 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
I have not seen this on a Mopar, but on a small block ford the studs will pull up the surface locally around the stud... went through this with a 302 once. The cure is a MLS gasket.......
I looked up 2 inch pin rods....... lot's available in the chevy listings..... but they are .927 pin.. not the cheapest route but more reliable........
Re: what can be done to a 360 for strength [Re: dizuster] #1546753
12/13/13 03:19 PM
12/13/13 03:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
bback when I was running the old 366 I would blow a head gasket once in a while using stock head bolts,switched over to ARP head bolts and problem went away, my opinion is the stock head bolts are too soft and will stretch too much under pressure, my opinion is use a good quality ARP head bolt at the very least on a cast iron head and head stud's on aluminim heads.
Re: what can be done to a 360 for strength [Re: SSDart] #1546754
12/13/13 03:26 PM
12/13/13 03:26 PM
Mt Morris Michigan
Mt Morris Michigan
i'll have to check prices on the 2" big end chevy rods and what it costs to turn the rod jounals down to that size. should lighten it up some using those rods.
Page 2 of 4 1 2 3 4
