Best trans brake button?
#1546310
12/11/13 12:23 PM
12/11/13 12:23 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Whats the best one out there. Biondo Terminator??? alternatives?
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
Re: Best trans brake button?
[Re: HemiDart68]
#1546311
12/11/13 12:31 PM
12/11/13 12:31 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
I just hold two wires together until its time to go! Something that I have found is its whats best for you. I know a couple of guys that have put 5 or 6 different buttons in their cars until they found what they liked best. The most common us the biondo adjustable button. Don't remember the name of the switch but dedenbear also makes on like it.
Back in the swing of things at Painless again! Great to be back!
[Re: dthemi]
#1546316
12/11/13 06:47 PM
12/11/13 06:47 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Grainger...I'll see if I can find the part # ...like $15
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: HemiDart68]
#1546318
12/11/13 06:54 PM
12/11/13 06:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is finally what I used... tried a few and then this one... I was more comfortable with it on the wheel but you can see I have it recessed below the wheel surface... this is the Biondo one
[Re: MR_P_BODY]
#1546319
12/11/13 08:47 PM
12/11/13 08:47 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
I use the Biondo Terminator.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: Eric]
#1546321
12/11/13 10:12 PM
12/11/13 10:12 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
The King of cheap has spoken!!
. 8.90's and winning races on a budget baby!!! Most of the expensive buttons are just micro-switches with a different name on the package.
Eric,you would use the button off your old shirt if would work and save you AJ uses one that looks like a firing button for nucular missle.
[Re: B G Racing]
#1546322
12/11/13 10:34 PM
12/11/13 10:34 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
I don't use anything special. Just a switch with and adjustable button. Mounted on the wheel, tried other places most consistent on the wheel.
[Re: Leigh]
#1546326
12/12/13 12:01 AM
12/12/13 12:01 AM
MR_P_BODY
The one I showed above on the wheel is adjustable and I needed that on my car... running box and no box classes I had to slow the reaction down... its suppose to change .3
[Re: Jeepmon]
#1546329
12/12/13 02:12 AM
12/12/13 02:12 AM
MR_P_BODY
I guess I am the only one that DOESNT like the Biondo Terminator... IMO, the length of the switch has too much inconsistency and I could do everything from an instant launch to never releasing the brake.. all depending on where I put my thumb..
I thought it was way too long and the rings were to broad of change... the one I show has a thread and is much shorter
[Re: Triple Threat]
#1546331
12/12/13 03:12 AM
12/12/13 03:12 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
This is the button I have in the car right now.. I found it to be easy to adjust and was able to get enough delay for me.. The only bad thing is my kid leaned on it sideways and the entire button broke apart in pieces.. and I guess I'm in the market for an adjustable button too.. http://www.biondoracing.com/product/HSA-O.html
[Re: Eric]
#1546334
12/12/13 03:50 PM
12/12/13 03:50 PM
HemiDart68
North of Detroit
Some nice options. I guess i just really need to decide if I want to a quick release or the adjustible kind. I have only made a few passes with a button, so its not like im used to either style. Might start out with a quick release and see how it goes, then go to a delay if i need it.
[Re: HemiDart68]
#1546336
12/12/13 10:00 PM
12/12/13 10:00 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
this B&M button is nice!!
[Re: JLaSalle]
#1546338
12/14/13 02:23 PM
12/14/13 02:23 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
If you're racing without a delay box,then get an adjustable button.Even if you need the car to react quickly you can shim it up,or adjust it up so it reacts almost like a quick button.Adust your launch rpm to get reaction times in the ballpark,then leave rpm alone and fine tune with the button.
I bought the Biondo that Jeepmon has in his link. Didn't have enough delay. Got a terminator and now I have it dialed in at my weekly track.
