Frontend pic... #1546114
12/10/13 06:53 PM
12/10/13 06:53 PM
parma,ohio
66littlebigmopar Offline OP
parma,ohio
Finally getting somewhere. Been a while since I've posted. Got the frontend back together and just narrowed the rearend. I'll have pics of that coming soon. Goal is just to have it on its own wheels by the end of the year.
Re: Frontend pic... [Re: 66littlebigmopar] #1546115
12/10/13 06:56 PM
12/10/13 06:56 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Looks great! I am pretty much doing the same thing up front other than what you are doing I am going to build my own lca's and put a rack on it.
Back in the swing of things at Painless again! Great to be back!
Re: Frontend pic... [Re: 66littlebigmopar] #1546116
12/10/13 07:29 PM
12/10/13 07:29 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
it sure looks nice any reason that you did not trim or remove any metal from the K member?
home of the
Sox and Martin Hemi Duster
Re: Frontend pic... [Re: 66littlebigmopar] #1546117
12/10/13 07:37 PM
12/10/13 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good... I dont understand why you wouldnt just
change over to a strut front end unless its a class...
$2K gives you the front end and brakes and way lighter
Re: Frontend pic... [Re: MR_P_BODY] #1546118
12/10/13 07:42 PM
12/10/13 07:42 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
And one day I will have that money. I already had bought the front brakes when I was going to do a 10" tire street car so I am going to follow that way. When I decide (if I decide) later down the road it will not be a problem doing the front clip and converting to strut. The chassis is based off a strut car from the firewall back.
Re: Frontend pic... [Re: BJS racing] #1546119
12/10/13 07:42 PM
12/10/13 07:42 PM
parma,ohio
parma,ohio
Yea I should have done a bunch of stuff differently, but on a tight budget using stuff I have off the shelf. When I started this project I lost my job so been just trying to plug away with it. I figured a bigblock 66 dart convertible with a 10 pnt cage should be cool enough.
Re: Frontend pic... [Re: 66littlebigmopar] #1546120
12/11/13 05:29 AM
12/11/13 05:29 AM
Oh
His and Her 69's Offline
Oh
Your strut rods washers are on backwards. Also I believe you don't have the spacer/bushing in between the strut rod rubbers as there is a lot of space between your nut and cotter pin. With the washer turned around it should be almost against the cotter pin when tightened. Without the spacer/bushing in between the nuts will loosen up.
Ask me how I know !!!
David
