Page 4 of 6 1 2 3 4 5 6
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME *DELETED* [Re: stumpy] #15443
05/26/05 02:30 PM
05/26/05 02:30 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Post deleted by stumpy
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15444
05/26/05 02:42 PM
05/26/05 02:42 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
im still going to try it.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15445
05/26/05 02:49 PM
05/26/05 02:49 PM
PA
BS27ROB Offline
BS27ROB  Offline
PA
I've enjoyed the debate, but can't help but wonder if thedriver ever got his problem solved?
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15446
05/26/05 02:50 PM
05/26/05 02:50 PM
Grand Prairie,Texas
Grand Prairie,Texas
My battery charger puts out 6v or 12v the only adjustment is the charging rate which is in 2, 10, 50 amps. The voltage does not change. I just tested it. As it charges the amperage drops not the charge voltage.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15447
05/26/05 02:57 PM
05/26/05 02:57 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
I found this on a website ( http://www.marine-electronics.net/techarticle/battery_faq/b_faq.htm )
it says under MYTHS about batteries:
"10.6. Test the alternator by disconnecting the battery with the engine running.
A battery as like a voltage stabilizer or filter to the pulsating DC produced by the charging system. Disconnecting a battery while the engine is running can destroy sensitive electronic components, for example, emission computer, audio system, cell phone, alarm system, etc., or even the charging system itself. These damages can occur because the voltage can rise to 40 volts or more. In the 1970s, removing a battery terminal was an accepted practice to test charging systems of that era. That is not the case today. Just say NO if anyone suggests this."
So like I said, old vs new. The alternator puts out a rectified DC signal. That means it was AC but the diodes rectified into DC. there is still a small amount of ripple on the output. with the battery in place, the battery acts like a shock absorber which mellows the ripple out. This ripple can ruin electronics in NEW vehicles. Old stuff like ours aren't affected because the technology is more resistant to the ripple.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: BS27ROB] #15448
05/26/05 03:00 PM
05/26/05 03:00 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
oh ya, what was the question again?
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: BS27ROB] #15449
05/26/05 03:00 PM
05/26/05 03:00 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Not yet.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15450
05/26/05 03:01 PM
05/26/05 03:01 PM
Grand Prairie,Texas
Grand Prairie,Texas
Thanks for the research. 40 is a long way from 400.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: amxautox] #15451
05/26/05 03:03 PM
05/26/05 03:03 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Not yet.
oh well, first disconnect the battery while its running and ......
Sorry, I couldnt resist.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15452
05/26/05 03:56 PM
05/26/05 03:56 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Ok this shows it fine. notice it says 40 volts or MORE!!!!! not peak at 18 or 40!
now all you have to do is realize that anything with electronics, and this means your old car with electronic ignition, electronic tachometer, electronic voltage regulator are succeptible to the damage caused by the prehistoric diagnostic method. This also includes any stereo thats been installed, and many many other possibilities.
If you look at a chrysler regulator, does it not say right on it "ELECTRONIC VOLTAGE REGULATOR"???? why is it so hard to accept that it has sensitive components in it??
This also mentions it can damage the alternator as well!!!
so lets see, how old are these cars that dont have alternators?? 62 ish???? wow thats old!!
Older than any car I own, so a person shouldnt do this on anything newer than 62 ish , how about that.
when did Chyrco come out with electronic ignition? I think it was 72?? so this includes anything newer than 72, plus anybody that has upgraded to electronic ignition.
when did Chyrco come out with the electronic voltage regulator?? Im not sure on this one, around 70? hmmm but also. most replacement regulators for the pre electronic ones are actually electronic ones inside the old mechanical style casing!!
so its plain to see that anything new enough to have an alternator, or ELECTRONICS, it is NOT ADVISEABLE TO DISCONNECT THE BATTERY WITH THE ENGINE RUNNING!!!
now check back to my original post. tell me its a good idea to remove the battery cable! the arcticle above states just to say NO to this suggestion!, and thats from a boat site!
oh and stumpy, what type of voltmeter are you using?? is it an analog type or a DVOM. An analog type will actually pass the current across a shunt and read closed circuit voltage. A DVOM will read the actual voltage. I suspect youre using some type with a shunt. They are not all the same.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15453
05/26/05 04:04 PM
05/26/05 04:04 PM
Grand Prairie,Texas
Grand Prairie,Texas
Read it again it says 70s cars, and "or more" doesn't mean 360v more. I do use a digital meter. The Canadian school system must be fantastic when a trade school grad knows more than an electrical engineer who works on the most advanced tactical strike fighter on earth.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15454
05/26/05 04:17 PM
05/26/05 04:17 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Read it again it says 70s cars, and "or more" doesn't mean 360v more. I do use a digital meter. The Canadian school system must be fantastic when a trade school grad knows more than an electrical engineer who works systems for the most advanced tactical strike fighter on earth.
Im sure its much better at explaining AUTOMOTIVE related issues. Just like its shown better than your old school chyrco master certificate.
How many alternators are there on tactical strike fighters??? All planes I know about use generators! They dont rectify ac voltage or need to.
and it says MORE!! first of all I said 200 was more likely.
let it go, youre wrong, Im right. theres no more arguement. The engineer didnt get it either, I think he does now. he got that info from a boat site!! not the skunkworks!!
and whats different from a 70 car and a 69 car??
you guys keep ignoring the fact that its NOT OK TO DO SO ON ANYTHING EQUIPPED WITH ELECTRONIC COMPONENTS!
as for your battery charger, it may have a shunt, or clamping diode inside it to prevent a voltage spike, very important when working around batterys.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15455
05/26/05 04:22 PM
05/26/05 04:22 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Ok, youre right. Thank you! I don't what I was thinking.
but I'm still gonna try it!!
and I'll let you all know what the voltage went to and I'll list everything that fries in the process.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15456
05/26/05 04:22 PM
05/26/05 04:22 PM
Grand Prairie,Texas
Grand Prairie,Texas
You have not convinced me or too many other people that your right just stubborn but you're young you'll learn you can't always win. I believe the only shunt here is the one between your ears you don't even recognize sarcasm when you read it.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15457
05/26/05 04:29 PM
05/26/05 04:29 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
save yourself some parts, and just disconnect the output terminal on the alternator. put your positive lead of a dvom on it. and place the negative one on the engine block. set it to auto range, VDC and light her up!
for best results, increase the rpm some! worst case scenario is you will damage the rectifier in your alternator. Check the ripple pattern before and after this test. This way you will see if you damaged one or more phases of the alternator. Cause otherwise you may believe for the next 20 years that you wernt responsible for the headlights dimming when at idle or the blower fan slowing down, and they never used to.
Have fun!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15458
05/26/05 04:35 PM
05/26/05 04:35 PM
Grand Prairie,Texas
Grand Prairie,Texas
My charging systems work just fine in stock form on both my old 74s and the lights don't dim the heater stays steady and I have run both of them a number of times with the battery disconected. I am waiting for more reasons that my charger doesn't work like you think it should. Face it your fighting a losing battle and you are grasping at straws to prove your point.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15459
05/26/05 04:37 PM
05/26/05 04:37 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
I started out this discussion with all due respect. Its dwindled now.
Its not a question of winning and losing, its a question of helping someone diagnose their car properly the first time without causing further damage.
Why are you not convinced? I gave you simple examples to try. The battery charger one did not work in your case,but I can assure you in many it will. I also gave you the one with disconnecting the alternator output one. If youre still not convinced, read the arcticle again. It clearly states what NOT TO DO.
What else do you need?
the only thing between my ears is mush, but somehow the ears have stayed open enough for the mush to absorb alot of info.
was that all sarcastic? Its hard to tell when its done in type.
Grasping at straws??? Get outta fantasy land and into reality!!
go check your alternators ripple pattern. Do you know how?
Chrycos are remarkably better at surviving this type of mechanic abuse compared to other makes. Good thing since you worked on them!
Maybe you can show me something that says you should disconnect your battery while running to test your alternator?????So far, Ive said not to, other people have said not to. The only one that says its ok is you. The engineer hasnt quite figured it out yet, but hes close!
Show me some facts!! Youre the only guy that believes youre right
lets see it!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15460
05/26/05 04:50 PM
05/26/05 04:50 PM
Georgia
72440CUDA Offline
72440CUDA  Offline
Georgia
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 72440CUDA] #15461
05/26/05 04:55 PM
05/26/05 04:55 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15462
05/26/05 04:59 PM
05/26/05 04:59 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
No, actually correct facts are what is accepted and so far you have spouted all kinds of FACTS but you still haven't proven your point, cause and affect. There is a very large difference between the new ICs and the original electronics. The early stuff was a lot sturdier and less affected by surges or spikes, or that ever you want to call it,than the stuff they use today mainly because it was simple. If it wasn't for dinosaur methods of testing your parents would have been walking every where they went because us dinosaurs did quite well with or testing methods long before you learned your way and long after. I can completely dismantle my car into it's smallest parts and rebuild it without opening a book or resorting to overpriced diagnostics machines can you?
You can do it all without a book huh?? Well so can I, but that dont make it the right way. I bet you can torque your heads without a wrench. Sure you might get them close, but are they right??? It will probably work ok in most cases, but how many will it not?? Do it right! I suppose you can remember all the float levels for every carb you worked on, but as long as its close it should be ok huh?? float level actually affects mixture, but, hey, youre close, good enough! No need to look up that spec. It might only run richer and tend to wash down the cylinder walls a tad, or just dilute the oil some, its ok, its close!
these dinosaur tactics are just what they are. Dinosaur, and we know what happened to them.
The better technician uses a book, cause he realizes he doesnt know everything, and is capable of researching the correct answer!
