Stuck carb ? #154529
11/21/08 03:48 PM
11/21/08 03:48 PM
Bloomington, Illernoise
cptn60 Offline OP
cptn60  Offline OP
Anyone ever have any luck getting a carb that is stuck closed, to open? Have an AFB I'd like to use, have Berryman's, diesel, anything you have used worked? Sure like to save it, if possible.
This space available for rent
Re: Stuck carb ? [Re: cptn60] #154530
11/21/08 04:45 PM
11/21/08 04:45 PM
If you already have a bucket of berrymans carb soup I think I'd toss it in there for several days. Since the intended usage of it is to loosen deposits I think that'd be a good 1st move.
Re: Stuck carb ? [Re: RapidRobert] #154531
11/21/08 05:05 PM
11/21/08 05:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Diesel fuel will do the same thing.
