Page 2 of 4 1 2 3 4
Re: 440 Source CNC heads [Re: MoparDonny] #154481
11/24/08 10:32 PM
11/24/08 10:32 PM
mopar heaven
rustbucket Offline
rustbucket  Offline
mopar heaven
There is one problem with the heads though. I went to order a set about a month ago and the only way they will sell them is complete with springs for a small cam. I want to run a hydraulic roller so the springs, stc would be useless! Why won't they sell them bare.... or has this changed
Re: 440 Source CNC heads [Re: rustbucket] #154482
11/24/08 10:42 PM
11/24/08 10:42 PM
detroit area
moderncylinder Offline
detroit area
you can buy just an inner spring from comp cams #974-16 making a double with enough tension for a flat tappet or hyd roller
Re: 440 Source CNC heads [Re: rustbucket] #154483
11/24/08 10:49 PM
11/24/08 10:49 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
I would think it's because MCH has adjusted the Valvetrain and checked all the clearances in the whole assembly and it's just part of the deal. I would think they could have bare CNC'd ones in the future. What exactly is a smallish cam. I think even the EDDY RPM's can handle up to 600 lift on stock springs, even though they likely won't handle it as I've heard before.
Don.
Re: 440 Source CNC heads [Re: moderncylinder] #154484
11/24/08 10:51 PM
11/24/08 10:51 PM
gregsdart Offline
gregsdart  Offline
If i were out to build a 700 hp budget motor, this is where i would start. The heads flow enough to make the power, and the price is right. Put them on a 535 inch rb 4.5 stroke shortblock, shift at 5800 rpm!
Re: 440 Source CNC heads [Re: moderncylinder] #154485
11/24/08 10:53 PM
11/24/08 10:53 PM
Ontario, Canada
Hyper Henry Offline
Hyper Henry  Offline
Ontario, Canada
They sound like a very good deal What about weight?? Same as Eddy, more than Eddy or less than the Eddy head??
Derrick
Re: 440 Source CNC heads [Re: moderncylinder] #154486
11/24/08 11:12 PM
11/24/08 11:12 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Would you recommend doing that for a comp XS290S or will the stock Stealth springs handle that cam?
dstryr, since 1986.
Re: 440 Source CNC heads [Re: dstryr] #154487
11/25/08 10:04 PM
11/25/08 10:04 PM
detroit area
detroit area
if its a car quicker than 12.0,, id add the inner
Re: 440 Source CNC heads [Re: rustbucket] #154488
11/25/08 10:16 PM
11/25/08 10:16 PM
WA 98043
thecarfarmer Offline
WA 98043
No mention of getting 'em w/o springs & etc. on their web page; they don't list any heads (ported or not) bare or bare w/ valves.
Kinda' sux, 'cause I have a solid roller, and have already purchased springs/retainers.
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: 440 Source CNC heads [Re: moderncylinder] #154489
11/25/08 10:19 PM
11/25/08 10:19 PM
Idaho
Runner Offline
Runner  Offline
Idaho
thats interesting, why does et make a differance?
Re: 440 Source CNC heads [Re: Runner] #154490
11/25/08 10:22 PM
11/25/08 10:22 PM
detroit area
detroit area
the quicker the car,,, the quicker the engine will accelerate,, therefore compounding valve acceleration..
Re: 440 Source CNC heads [Re: moderncylinder] #154491
11/26/08 03:35 AM
11/26/08 03:35 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
this really doesn't make any sence, the ET really hasnät got much to do with the engines accelration rate. How aboout the number of gears, engine rpm range, total gear ratio etc?
Plynouth VIP '67 TT IC EFI
Re: 440 Source CNC heads [Re: jyrki] #154492
11/26/08 08:47 AM
11/26/08 08:47 AM
detroit area
detroit area
its a generalization,, more power the engine makes the quicker it will acclerate the car theefore acclerating the engine/valvetrain quicker,,, common sense..
you could have some 572 with a small hyd cam that has a 2.73 gear that can go 11's , or something to that nature,, that makes my reasoning fail,, but again its a generalization.
like a 590 cam in a 4000lb car with a 440 that is pump gas and runs 12.50's,, then take a 590 cam in a 528 or 540 that has high compression in a 2500lb drag car,, the spring requirements are not the same,, again common sense..
i have "general" rules for setting heads up based on cam, rocker ratios, rear end ratio, total lift, how many gears, how quick the car is overall,, most people put in the rear end ratio to max engine speed at the expected targeted 1320ft mark.
Re: 440 Source CNC heads [Re: moderncylinder] #154493
11/26/08 09:28 AM
11/26/08 09:28 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Thanks MCH for the inner spring tip.
Will the Source retainers work? or is there a better choice?
Re: 440 Source CNC heads [Re: thecarfarmer] #154494
11/26/08 12:41 PM
11/26/08 12:41 PM
mopar heaven
rustbucket Offline
rustbucket  Offline
mopar heaven
-bill
This is my point exactly. If you have parts already why would youbuy them again. Does anyone else make you buy their heads complete!!!!!
Re: 440 Source CNC heads [Re: rustbucket] #154495
11/26/08 12:53 PM
11/26/08 12:53 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If memory serves, brandon's reasoning for this was so many people wanted to buy the heads bare but with valves. He decided that he would just sell the whole thing because you'd still be ahead of the game even if you had to replace the springs/retainers. Probably just easier for him to sell them whole.
Re: 440 Source CNC heads [Re: rustbucket] #154496
11/26/08 01:01 PM
11/26/08 01:01 PM
detroit area
detroit area
maybe he could sell them without the springs and so on,,, maybe he would drop the price 30 dollars or something,, see them for 869.00,,, or even maybe 859.00..
edelbrock does not sell their performer head as a head w valves only,, if you bought the casting and then bought valves you would have the same amount of money as if you bought the assembled head from them.
what i would be asking for is a "race" version with a double spring and 10 degree locks and retainers,,, maybe he could offer that kind of an upgrade for 50-75 bucks more.
jeff
Re: 440 Source CNC heads [Re: moderncylinder] #154497
11/26/08 01:35 PM
11/26/08 01:35 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Ding, ding, ding...we have a winner!
Re: 440 Source CNC heads [Re: Dave64] #154498
11/26/08 02:10 PM
11/26/08 02:10 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Id buy a set with the spring upgrade for sure.
Re: 440 Source CNC heads [Re: domingo] #154499
11/26/08 02:45 PM
11/26/08 02:45 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I bet that 440source doesn't sell them sans springs because it requires a separate SKU/stocking number. The difference of $30 doesn't make economic sense due to potential lost sales from the complete units.
Easier to stock one unit for the marginal difference.
Heck, if I bought them and didn't want the springs/retainers, I'd give them to someone doing a milder build. If $30 is a budget buster?
Re: 440 Source CNC heads [Re: RobX4406] #154500
11/26/08 02:57 PM
11/26/08 02:57 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Page 2 of 4 1 2 3 4
