Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mr.Yuck] #1543433
12/05/13 10:41 AM
12/05/13 10:41 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I run a Carter race pump ?? and use a carter back up electric boost pump at the track..and after the car sits for a month or so It's nice to pump up the fuel without cranking the motor...and it's always there if the mech pump takes a sh--..I can get home on the electric pump..
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mopar Guy] #1543434
12/05/13 11:37 AM
12/05/13 11:37 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
CV makes a billet pump for Nascar that fits bb that i found and i gues that that would be one of the nasty once that will need a regulator but i havent tryed mine yet !
Where would I get one of these? I run the Clay Smith pump now, like to try something different in the future.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mr.Yuck] #1543435
12/05/13 11:40 AM
12/05/13 11:40 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
In any even the carter and holley pumps will get a BB car well into the 11's w/o an issue, even w/ tiny 5/16 line.
Yep. IIRC, Dwayne Porter's 440 B-body was in the mid-to-high 10s w/ a mechanical pump and still had the OEM 5/16" line.
My only concern w/ a mechanical pump was when I was still running a Six Pack on The MoPig and had some vapor-lock problems crop up on occasion. The fuel line insulation I added to deal with the issue seemed to work, but certainly took away from the sleeper image.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Mopar Guy] #1543436
12/05/13 03:50 PM
12/05/13 03:50 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
i picked up one of these my self awhile back and have yet to use it. any body using one of these? i may try mine on a turbo project.
[image][/image]
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Diplomat440] #1543437
12/05/13 07:01 PM
12/05/13 07:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
There was a guy on FABO that I think worked for airtex that clames the airtex stock replacement pump will hold something like 5 psi with no drop off at hi rpms. Not sure if true but if it's a low 12 to low 11 sec car might be worth a shot, if it's starving at the big end bring it back.
Re: Sreet/strip guys...mechanical fuel pump?? [Re: ademon] #1543438
12/05/13 07:49 PM
12/05/13 07:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I think the biggest obstacle for the stock pump location by itself is over coming g-forces (the weight of the fuel) bringing it from the back, which is also the major problem for the smaller electric pumps with a big line(8-10) 3/8 line would be the max I would use. Mech and small electric pusher will work well into the lower 10s
Re: Sreet/strip guys...mechanical fuel pump?? [Re: Diplomat440] #1543439
12/06/13 10:35 AM
12/06/13 10:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
[image][/image]
It will work as long as you can boost reference it. I ran a hi-po carter on my old S/C'd 440. All I did was tap a small 1/4 line into the top of the pump (it's already there maybe for venting)and ran a line from the head unit to the pump.
