Page 1 of 3 1 2 3
Hughes Whiplash Cams #1543314
12/03/13 09:28 PM
12/03/13 09:28 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Has anyone used a Hughes Whiplash cam in their 440? I just read a dyno sheet where Dunnuck Racing made 491 hp and 578 ft-lbs of torque in a 9.2:1 440 with out of the box Edelbrock RPM heads and intake. I find that pretty impressive, but wondering if anyone has actual real world experience on the street?
Re: Hughes Whiplash Cams [Re: elmor353] #1543315
12/03/13 09:45 PM
12/03/13 09:45 PM
No actual experience with them but there's been several good reviews on here about em. I did use a custom circle track cam of his' & when the RPM got up on the cam it turned on like crazy & scared me. I just talked to Dave earlier today. I'd recommend his stuff, wouldn't be cheap tho but nothing good is (for the most part)
Re: Hughes Whiplash Cams [Re: RapidRobert] #1543316
12/04/13 01:50 AM
12/04/13 01:50 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
I have a 73 440 HP with only 40,000 miles on it. Right now it has a Summit cam, 224/234 duration @.050, .466/.488 lift int/ex, LSA 114. It runs okay, but I don't have enough compression for it. I think the Whiplash cam would be a much better fit.
Re: Hughes Whiplash Cams [Re: elmor353] #1543317
12/04/13 01:05 PM
12/04/13 01:05 PM
dogdays Offline
dogdays  Offline
Do a search on the trucks page and read member Scratchinfortraction's rave reviews of his Whiplash cam.
My own opinion is that they're gimmick cams, I am not interested in a lumpy idle just so my car "sounds tough". BUT if that's what you want, they get the job done with good power production to boot.
R.
Re: Hughes Whiplash Cams [Re: dogdays] #1543318
12/05/13 01:05 AM
12/05/13 01:05 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Yeah, I like the way they sound but, I like the fact that they are designed for low compression engines and increase cylinder pressure. 491 hp and 578 ft-lbs of torque in a basically stock engine is fairly impressive. It's going to be used in my 77 D100 swb. It's a cruiser and parts chaser. Might make a pass or two at my local dragstrip but, it will mostly be a driver.
Re: Hughes Whiplash Cams [Re: elmor353] #1543319
12/05/13 10:26 AM
12/05/13 10:26 AM
scratchnfotraction Offline
I have a 88-440 truck and waiting on the down time to swap the whiplash cam into the 440.
I swaped in the 318 whiplash roller cam for the magnum engine in the stock JY 91 pre-mag #302 headed 318.
sounds nasty and works in my 85 stepside. has a lot of lowend torque and great throttle responce. woke it right up.
I am in the middle of swaping a NV4500 5 speed into the stepside behind the whiplash roller 318 now.
then the 440 truck is up for a freshin up with a set of 452 heads/headers.
heck, just the edelbroke RPM intake/edelbroke q-jet woke the 78 lopo smogger 440 up in the 88 truck with a 727/3.91sg.
the whiplash may be a gimmick...but that gimmick sure works in a lopo mopar for a daily driver..I sure have more fun with less engine than most have with more engine on the street.
I have more use for a street engine than a race engine.
check out member Junky and his 383 whiplash.. he was real happy with his also.
Re: Hughes Whiplash Cams [Re: scratchnfotraction] #1543320
12/05/13 06:51 PM
12/05/13 06:51 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Can't wait for spring. Too darn cold right now to be wrenching on my rig. Definitely going to install the RB Whiplash cam. Nothing like rolling into a cruise in and having heads turn. This thing rarely will see anything over 5 grand on the street, but if it makes more power from idle to 5000 rpm, I'll be a happy camper.
Re: Hughes Whiplash Cams [Re: elmor353] #1543321
12/05/13 09:01 PM
12/05/13 09:01 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yea, these cams are VERY gimmicky...
bone stock 5.9 Magnum. 2bbl M1 EFI intake edelbrock small tube headers and SCT tuner.
add one 5.9 Whiplash cam (222°/228° @ .050, .544 lift, 107 LSA installed at 104) and suddenly I'm putting down 285 hp to the wheels (nearly 100 hp more than stock) with more HP left on the table...my stock TB was causing me to build up to 3" of manifold vacuum at WOT above 4,000 RPM. Truck was running 14.2 1/4 miles at 97-99 mph with traction limited 60' times of 2.2-2.3 With traction, that 4,000 lb street truck would have been into the 13s.
not bad when bone stock it was lucky to run a 15.2
Gimmick or not, they flat out work for cheap "junkyard motors" that are still low compression, stock heads, etc.
**Photobucket sucks**
Re: Hughes Whiplash Cams [Re: 70Cuda383] #1543322
12/05/13 10:51 PM
12/05/13 10:51 PM
yea, I forgot about your vids of the DAK on the dyno you should post that up for him to hear/see in action.
it is not chebby lobes on a mopar stick for sure.
Re: Hughes Whiplash Cams [Re: scratchnfotraction] #1543323
12/06/13 08:36 PM
12/06/13 08:36 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
There's no gimmick anything about these cams. Hughes just put a cool name on the stick.
I installed one in my 383 a year or two ago. I was very, very pleased with the performance of the came once I tuned the engine. Yeah, it has a nice lumpy sound. But, dude, it winds to 6000 RPM like there's no tomorrow. I mean for a 383 it gets with it! From a stop, no foot breaking, just mash the go peddle, it will blow the 275/60/15's off the back of my Coronet, hit 2nd and does a nice little wiggle due to tires spinning. I need stickier tires.
Hughes designed it to run in a stock to very mildly modified engine with no more than 9 to 1 compression in mind. My engine has had some head work and other goodies installed. They did an excellent job of designing it.
107 lobe separation, installed ceterline 102.
229 degrees intake and 242 degrees exhaust at 0.050" tappet lift.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Hughes Whiplash Cams [Re: Junky] #1543324
12/06/13 10:32 PM
12/06/13 10:32 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Mine only pulls to 5300 or so. That was my only complaint. But Dwayne porter says that I was valve spring limited even though I was using the ones they spec'd for the cam. We'll see how it does with eddy aluminum heads. My shop is setting them up for 140 lbs seat pressure.
Re: Hughes Whiplash Cams [Re: Junky] #1543325
12/06/13 11:52 PM
12/06/13 11:52 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
What is the small block equivalent (warmed 340 in my case)?
Re: Hughes Whiplash Cams [Re: JonC] #1543326
12/07/13 02:26 AM
12/07/13 02:26 AM
USA
max Offline
super gas
max  Offline
super gas
USA
What stall speed convertor are you guys using with those cams?
I thought about buying one of those cams for my 383 but it's in front of a 1962 trans and the stock convertor doesn't have much of a stall to it.
Re: Hughes Whiplash Cams [Re: JonC] #1543327
12/07/13 02:12 PM
12/07/13 02:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Depends if you want LA Flat tappet stuff or magnum roller
If you go to Hughes website they'll have them listed as 'whiplash'. For example, under small block magnum, cams, they have listed 5.2 whiplash and 5.9 whiplash
The common theme on them is the 107 LSA.
Re: Hughes Whiplash Cams [Re: scratchnfotraction] #1543328
12/07/13 03:38 PM
12/07/13 03:38 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Beautiful truck, Scratchin'!! Dodge should have offered that color scheme/trim package back then for the 88' pickups. Would have been a big seller. Hey, let us know how well that Whiplash cam runs in the 440. I figure that truck weighs in a 3800-3900 lbs? Probably similar performance as a 68'-69' 440 powered B-Body. Good luck with it and have BIG fun driving it.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Hughes Whiplash Cams [Re: max] #1543329
12/07/13 04:31 PM
12/07/13 04:31 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Mine's a stick shift.
but I would imagine that you don't need much stall. I can roll out and let the clutch all the way out, then once I'm rolling along (maybe around 1000-1200 rpm), stand on it, and the tires go up in smoke immediately, no delay waiting for the RPM to come up.
Re: Hughes Whiplash Cams [Re: 70Cuda383] #1543330
12/07/13 04:42 PM
12/07/13 04:42 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Re: Hughes Whiplash Cams [Re: 70Cuda383] #1543331
12/07/13 06:45 PM
12/07/13 06:45 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Very nice! Can't wait for warmer weather. The 440 will definitely get a Whiplash cam.
Re: Hughes Whiplash Cams [Re: max] #1543332
12/09/13 03:16 PM
12/09/13 03:16 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I run a custom built 12" tight torque converter that will flash to 2500 RPM in 1st gear from a stop.
Re: Hughes Whiplash Cams [Re: Junky] #1543333
12/09/13 09:53 PM
12/09/13 09:53 PM
Central NC
gch Offline
gch  Offline
Central NC
Just seems like a bit much cam for your typical 7.5-1 smogger in a heavy highway geared pig like my newport.
Page 1 of 3 1 2 3
