Page 2 of 3 1 2 3
Re: Time to Paint the D100. [Re: Polarapete] #1543255
12/06/13 05:13 PM
12/06/13 05:13 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
My garage is small, 24x24 and it is semi insulated, the ceiling, peak, overhead door, and two of the walls. Ihave one of those 50,000 BTU natural gas heaters mounted high on one end. I can warm it even on the coldest days into the 80's if I want. I usually keep it in the mid 40's all the time and turn it up when I'm out there. In the old days I used to use one of those Dual Mr Sun Radient heaters on a propane bottle with a box fan behind it to move air. And that would make it comforatable. The NG heater is the way to go if you can.
Re: Time to Paint the D100. [Re: jstollfu] #1543256
12/06/13 05:19 PM
12/06/13 05:19 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Now I know what I want for Christmas
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Time to Paint the D100. [Re: jstollfu] #1543257
03/01/14 12:21 AM
03/01/14 12:21 AM
Az
HOT IN AZ Offline
HOT IN AZ  Offline
Az
Any updates, can't wait to see it painted?
Re: Time to Paint the D100. [Re: HOT IN AZ] #1543258
03/21/14 10:34 AM
03/21/14 10:34 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Been awhile since I've done much to the truck. In December I slipped on the ice and fell in a bad way. I pulled the quad and tore the ACL in my right leg. Which kept me from doing anything in the garage for about 2 1/2 months. Combine that with the miserable winter we had. I just started back on the project recently. I did get the inside of box roughed out and primed.
Re: Time to Paint the D100. [Re: jstollfu] #1543259
03/21/14 10:35 AM
03/21/14 10:35 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Tailgate primed too.
Re: Time to Paint the D100. [Re: jstollfu] #1543260
03/21/14 10:39 AM
03/21/14 10:39 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Removing paint from the body. Truck is very solid. Only ran into a couple small spots of rust.
Re: Time to Paint the D100. [Re: jstollfu] #1543261
03/21/14 10:44 AM
03/21/14 10:44 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
At some point the paint must have flaked off under the side mouldings. Then it sat out like that as there is some pitting on the box side. However there is no rust through. The other side of the box did not have this problem.
Re: Time to Paint the D100. [Re: jstollfu] #1543262
03/21/14 03:04 PM
03/21/14 03:04 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Im far from paint. Looking good. Always nice to start with a fairly solid foundation
Re: Time to Paint the D100. [Re: 76dodgeboy] #1543263
03/21/14 09:01 PM
03/21/14 09:01 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Looking good and solid.
Re: Time to Paint the D100. [Re: moparborn] #1543264
03/23/14 02:13 AM
03/23/14 02:13 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Nice progress
Re: Time to Paint the D100. [Re: 77ProStreet] #1543265
03/25/14 05:55 PM
03/25/14 05:55 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Other side sanded. No rust surprises. Truack is extremely solid for it's age.
Re: Time to Paint the D100. [Re: jstollfu] #1543266
03/25/14 08:48 PM
03/25/14 08:48 PM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
If only there was a way to guarantee it wouldn't rust, I'd clear coat it. Oh well, it'll look great back in its original colors. The rest of us can only wish to start with such a solid foundation.
OIF V and OEF X veteran and proud of it!
Re: Time to Paint the D100. [Re: 69HemiGTX] #1543267
05/12/14 12:53 PM
05/12/14 12:53 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Got the truck back from the paint shop late Saturday.
Re: Time to Paint the D100. [Re: jstollfu] #1543268
05/12/14 12:55 PM
05/12/14 12:55 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
They jammed up the Passengers side door latch, not sure how thy did it but I need to replace the latch.
Re: Time to Paint the D100. [Re: jstollfu] #1543269
05/12/14 12:55 PM
05/12/14 12:55 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
I have all new NOS side trim for it.
Re: Time to Paint the D100. [Re: jstollfu] #1543270
05/12/14 12:57 PM
05/12/14 12:57 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Now the fun of putting it all back together.
Re: Time to Paint the D100. [Re: jstollfu] #1543271
05/12/14 01:00 PM
05/12/14 01:00 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Factory colors like them or not are spot on..
Re: Time to Paint the D100. [Re: jstollfu] #1543272
05/12/14 03:06 PM
05/12/14 03:06 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Lookin' good!
Re: Time to Paint the D100. [Re: jstollfu] #1543273
05/12/14 03:22 PM
05/12/14 03:22 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
wow, what a difference a new paint job will make looks straight as a arrow too, awesome looking great
Re: Time to Paint the D100. [Re: 98RAM1500] #1543274
05/12/14 08:49 PM
05/12/14 08:49 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Very very nice. I love that you're putting the side trim back on it.
Page 2 of 3 1 2 3
