automatic transmission question
#1537806
11/21/13 06:07 PM
11/21/13 06:07 PM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Hey fellas, got an A904 in my 73 Dart Sport 340. Planning to rebuild it in a week or so, but, it has an issue that is a bit odd to me.
I top it off with fluid, drive it and all is fine. If I let it sit over night, no problem. However, if it sits for 24 hours or more, it leaks about 2 quarts onto the floor.
My guess is that the converter is draining back down to the input shaft and thats where the trans fluid is coming from. but, if thats what it is, how do I stop it?
Next question, Im ordering the parts to rebuild it. Anyone have any input on what converter and what trans kit to order. I dont plan to run a high stall converter or anything since its just a mild cruiser.
Laine.
Re: automatic transmission question
[Re: Lmopar69]
#1537808
11/21/13 06:20 PM
11/21/13 06:20 PM
RapidRobert
clean it off with the car wash wand then the next day see specifically where it is leaking from. Sprinkling talcum power on it can help pinpoint a leak as they can be deceptive. I think there's 4 or 5 locations where it could be leaking from but not from the input shaft (front pump seal) when it ain't running since the fluid level ain't that high. Transgo TF1 shift kit & Transgo used to offer a converter that was a bit more tight than stock (more efficient) for a daily driver & no doubt converter tech has improved in 40 yrs if a tighter converter is what you are after. (it does have a 340 but you did say mild cruising )
[Re: teflon]
#1537810
11/21/13 07:06 PM
11/21/13 07:06 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Also if you use a Transgo shift improver kit, they are supplied with a new manual valve which eliminates drainback.
It does ???? I never heard that before
[Re: JohnRR]
#1537811
11/21/13 08:03 PM
11/21/13 08:03 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
When they leak like that it can also be the shift shaft seal. 2 quarts is a ton of trans oil. It must look like they beached the Exxon Valdez at your place.
[Re: teflon]
#1537812
11/21/13 08:04 PM
11/21/13 08:04 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nothing can eliminate converter drainback, the Transgo valve merely allows the converter to recharge in Park.
