Re: No heat from defrost 77 Ply Gran Fury wagon
[Re: Polarapete]
#1537730
11/21/13 05:03 PM
11/21/13 05:03 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
By vent I would assume you mean the floor vent and you are getting no heat at all. The way the question is asked it makes me wonder if you have heat in one position only, or no heat at all. Being as you said you flushed it I am leaning more towards no heat at all. If no heat at all you need to make sure the cable or vacuum line actually is opening the valve in the incoming hose. The heater air box could also be plugged with debris, also make sure the motor is actually getting as hot as it should. If you mean you have heat but can't control where it comes out, then like said check the switching system.
I have mechanical Aptitude. I can screw up anything.
[Re: Blown 68 R/T]
#1537733
11/21/13 05:28 PM
11/21/13 05:28 PM
bboogieart
Lost and Spaced
So the hot to cold control is no longer an issue as you used a straight pipe. You flushed the core so that is not the issue. The next thing is make sure your vents are opening. That is what I guess the first answer was about. Check the vacuum diaphragm for operation. The heater box and the vents that move the air into the cabin from the air box could still be plugged with debris.
[Re: BulletBob]
#1537735
11/21/13 08:45 PM
11/21/13 08:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sounds like a blend air door issue, the FSM had the procedures on how to test.
[Re: BulletBob]
#1537736
11/21/13 11:21 PM
11/21/13 11:21 PM
Posts: 525 Shannonville, Ont
Blown 68 R/T
Shannonville, Ont
Just sell it to me to go with the 59K original 75' I've got
This one only has 65k on it. 400 4bbl.
I'll check all the doors to see if they are working.
