Re: sleeves in Hemi block
[Re: Cab_Burge]
#1537549
11/21/13 08:31 AM
11/21/13 08:31 AM
Posts: 10,003 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Not a Hemi, but a 426 wedge, I went .100 over, raced it for some time. Sonic check, see what your bore options are, then see what rings are available. If you have to spend a lot, you might as well get everything you can out of it by using the best rings (thinner?) for the job. You also may have the option of less than a full set of sleeves for a certain bore. No two cylinders will be exactly the same.
[Re: cudaman1969]
#1537552
11/21/13 12:23 PM
11/21/13 12:23 PM
Posts: 2,649 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Lay a stock head gasket on the deck. See if the chamfer goes beyond the notch that is in the gasket. We used to sand out the top of the cylinder to match the gasket on a pro stock engine. It doesn't hurt anything on a street engine but would be illegal in stock or super stock.
2011 Drag Pak Challenger
[Re: cdp]
#1537555
04/18/14 04:45 PM
04/18/14 04:45 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Sonic test first. Many can go .070 over.Back when I had my shop I saved a lot of used up Hemi blocks. Did them with a Kwik-Way bar.I used a very thick sleeve and had about.255 wall before honing .005 on the CK-10 to stock bore size.At that time I used Nylen sleeves but I never had any issues (I think they were some sort of iron mix).Procedure was do only one cyl at at time on each bank skipping over the ajoining cyl. So I would do #4 flip it do #5 flip it do #8 flip it do #1 etc.1/4 inch or more retainer groove at the bottom of each cyl and about 1/16 sticking out the top.Filed and stoned off excess continue to next cyl.Green Loctite sleeve retainer to seal off the water.Squared the block afterwards.Worked very well even on paper thin pro stock blocks.Lots of work and time.This procedure seemed best to prevent the block from twisting much and they were very easy to square up.BTW back then it was $400.00 incl sleeves.Should be much easier now the the modern equipment.
Leave the gun.......take the Cannoli's....Mike
