Just in case you don't want to sell me your car cheap, check this out.
This is a true pressure bleeder, not no suction gimmick and works 100% every time without fail.
I have been using it for 25 years now.
It holds 1 gallon of brake fluid and has a rubber diaphragm inside separating the air pressure from the brake fluid. I have taken it apart at least 3 times in 25 years to clean it up, paint it to prevent corrosion, replace hardware and to inspect the diaphragm.
I pressurize the lower half with about 10-20 psi.
Then bleed any air out of the upper chamber before using. Connect it to the master cylinder and open the valve and apply 15 or so psi to your master cylinder.
Open the bleeders and the fluid shoots out allowing you to bleed each line 100% in seconds per wheel including the master cylinder.
I just put new pads and rotors on this truck and flushed the brake lines while I was at it, I just let it go on the floor and pressure wash it up when I'm done.
I keep brake fluid in it all year long and sometimes it sit's a for year until I use it again. The fluid stays good because it not exposed to any air, it's always under pressure to keep the air out.
I also use it to flush my brakes for preventive maintenance also.
The master cylinder adaptator on the right is the one I use on old cars with a double reservoir.
Find someone who has one and you can be sure it's bleed 100%, maybe that's not your problem. We can only guess from here, at least you know what a pressure bleeder looks like now.
![](http://i21.photobucket.com/albums/b260/challenger19711/Phase%205/boat%20trailer/MVC-858S-1.jpg)
Right after a fresh rebuild, little paint and new hardware and hose.
