Re: Engine stand/cart
[Re: JMCFAN]
#1537130
11/20/13 04:03 PM
11/20/13 04:03 PM
Posts: 20,147 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Harbor Freight sells one and you can get a 25% off coupon online.
[Re: dOc !]
#1537132
11/20/13 04:38 PM
11/20/13 04:38 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I built one out of 2x6’s and 2x8's .....very sturdy ..,
What, no fiberglass?
[Re: markrr]
#1537134
11/20/13 06:43 PM
11/20/13 06:43 PM
Posts: 1,177 People's Republic of Kali
70runner
70runner, that's nice! I think I'll try making my own. I bought a welder years ago and have yet to use it. I'll make this my first welding project. If it doesn't work I'll use wood. I can get plenty of good, used pieces of wood for free. Thanks.
Makes a great welding project. Mine is actually an adaptation of a commercial product I was able to take measurements on. Here it is in final checkout before 440 break-in run.
[Re: markrr]
#1537142
11/20/13 10:12 PM
11/20/13 10:12 PM
RapidRobert
As said they are pricey. I'd make one with square tubing & bolt it together & some of it will need to be welded & truck it to a welder or pay him to come to you if he has a portable welder. You'll still come out way ahead plus the personal satisfaction of having done it yourself
[Re: dOc !]
#1537144
11/20/13 11:46 PM
11/20/13 11:46 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
I built one out of 2x6's and 2x8's .....very sturdy ..,
pics or it never happened!...
[Re: markrr]
#1537147
11/21/13 12:30 PM
11/21/13 12:30 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
not much to building one, you really just need a way to hold a rad in front of an engine and keep the engine from falling over. i've got maybe $40 in mine and thats just the mig gas and welding wire. just used it yesterday for a successful break in [image] [/image]
[Re: Diplomat440]
#1537150
11/21/13 02:33 PM
11/21/13 02:33 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
Cheap ole furniture moving dollies work great for engine carts. may have to notch out the center board for pan clearance though. I have had many 440's on mine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Diplomat440]
#1537151
11/21/13 04:57 PM
11/21/13 04:57 PM
Posts: 3,049 Bowling Green, KY
cudaboy
Bowling Green, KY
since the starter bolts to the bell you have to have a bell and flywheel or an automatic trans and torque converter to start the engine.
Thanks. I knew it was a dumb question, I really didn't think it through.
Dennis
[Re: cudaboy]
#1537152
11/21/13 05:16 PM
11/21/13 05:16 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't like the idea of running a motor up on a stand. All the stands I have seen are kind of high off the ground. Also with the motor mounted from the back How does the trans attach, so it can run? I always wanted to build a stand onto a pick up frame, using the front end and put a hitch on it. That way I could work on motors, and also sell motors that can be seen and heard running. Then deliver them as well.
I have mechanical Aptitude. I can screw up anything.
[Re: goldmember]
#1537153
11/21/13 11:23 PM
11/21/13 11:23 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
It shouldn't be too hard to do.
heplayswithhisownMEMBER is pretty darn close ! ..
