Can I trim a bed liner? #1534771
11/18/13 04:07 PM
11/18/13 04:07 PM
St. Louis, Mo
3
318 Stroker Offline OP
St. Louis, Mo
I just bought a 02 Dakota with a camper shell. I've found a factory Dodge liner for sale, but it's the over the bedside style. How easy is it to trim one of these to fit under the inside bed rail?
Re: Can I trim a bed liner? [Re: 318 Stroker] #1534772
11/18/13 04:10 PM
11/18/13 04:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why do you need to trim it? The camper should fit even on an over the rail liner.
Re: Can I trim a bed liner? [Re: 318 Stroker] #1534773
11/18/13 04:13 PM
11/18/13 04:13 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
The over the rail liners are moulded differently than the under the rail ones. You CAN trim it, but it might not "sit" tight to bed/inside part of the rail. If you trim it to just remove the top part of the liner (portion that goes over the rail), and leave the part that is against the inside (vertical) part of the rail- you can hold it against it with some screws
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Can I trim a bed liner? [Re: stumpy] #1534774
11/18/13 04:14 PM
11/18/13 04:14 PM
St. Louis, Mo
3
St. Louis, Mo
The camper has special C-clamp type camper clamps that clamp over the inside camper rail and underneath the lip of the inside bed rail. With the over-the-rail bed-liner, no way to clamp the camper shell down.
Re: Can I trim a bed liner? [Re: 318 Stroker] #1534775
11/18/13 04:36 PM
11/18/13 04:36 PM
BDW Offline
BDW  Offline
Instead of trimming the whole section, what about just notching out sections where needed?
Re: Can I trim a bed liner? [Re: BDW] #1534776
11/18/13 04:45 PM
11/18/13 04:45 PM
St. Louis, Mo
3
St. Louis, Mo
Actually, I thought about that too. Anybody ever cut or notch one, and how hard was it to do? Did you use a razor knife?
Re: Can I trim a bed liner? [Re: 318 Stroker] #1534777
11/18/13 05:18 PM
11/18/13 05:18 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I cut triangle shapes in my '01 Ram's bedliner so that I could get to the tie-down points easily. Just used a razor knife, and it cut more easily than you'd think. I agree that you should just cut notches. If for some reason that doesn't work, you can always cut more.
Re: Can I trim a bed liner? [Re: 318 Stroker] #1534778
11/18/13 05:24 PM
11/18/13 05:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would use large hole saws, that why it at least looks uniform.
Re: Can I trim a bed liner? [Re: Challenger 1] #1534779
11/18/13 09:47 PM
11/18/13 09:47 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
I got a liner this summer for my '97 pickup, the plastic kind that goes under the rails. That was all fine and good but the tailgate piece goes over the top of the tailgate. I have a stainless piece on top already so we took a skilsaw and cut the top plastic lip off, so at least the stainless still shows instead of being covered up. Works for me.
Re: Can I trim a bed liner? [Re: Challenger 1] #1534780
11/18/13 09:55 PM
11/18/13 09:55 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Thats how they did mine Holesaw
Re: Can I trim a bed liner? [Re: Moparlar] #1534781
11/19/13 01:12 AM
11/19/13 01:12 AM
St. Louis, Mo
3
St. Louis, Mo
Thanks for the ideas guys
