68 340 4 Speed Cam Shaft #1534712
11/18/13 01:46 PM
11/18/13 01:46 PM
South Dakota
Pa karp Offline OP
Pa karp  Offline OP
South Dakota
Does any manufacturer make a cam shaft with the 340 4 speed spec? The cam shaft # is 2899205.
Re: 68 340 4 Speed Cam Shaft [Re: Pa karp] #1534713
11/18/13 02:52 PM
11/18/13 02:52 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Comp Cams does
Re: 68 340 4 Speed Cam Shaft [Re: Pa karp] #1534714
11/18/13 05:30 PM
11/18/13 05:30 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
I always thought why there was no difference in the horsepower rating between the 2 cams? Any ideas?
Re: 68 340 4 Speed Cam Shaft [Re: formula_s] #1534715
11/18/13 09:58 PM
11/18/13 09:58 PM
South Dakota
Pa karp Offline OP
Pa karp  Offline OP
South Dakota
Same horsepower, but the 4 speed cam was the better cam. Both the autos and 4 speeds had the same cam for 69. A 68 4 speed would out run a 69.
Curt Rees
Re: 68 340 4 Speed Cam Shaft [Re: Pa karp] #1534716
11/18/13 11:07 PM
11/18/13 11:07 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The 4 speed cam did make more power even though they were both rated at 275HP. They also would not idle dead smooth like the auto cam. Its too bad that Chrysler stopped using them in stick cars. It was a great package and wasn't offered for very long.
If you dont find one NOS or an off the shelf copy, PM me, I can get you one that is basically a modern copy and produces more power. You would need to run a different valve spring.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 68 340 4 Speed Cam Shaft [Re: Rapid340] #1534717
11/19/13 12:46 AM
11/19/13 12:46 AM
SE PA
Yellow Fever Offline
SE PA
340 4 barrel 68 man trans Hydraulic 444/453 276/284
340 4 barrel Hydraulic 430/444 268/276
340 70 six pak Hydraulic 430/444 268/276 (adjustable rockers)
Re: 68 340 4 Speed Cam Shaft [Re: Yellow Fever] #1534718
11/19/13 01:45 AM
11/19/13 01:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep the 1968 340 stick cars were the only ones to get the more radical cam. My brother bought a 68 Dart 340 four speed in 1973 and I will always remember how it had a lumpy idle. But boy did that 340 run hard for a stock 340 car. Ron
Re: 68 340 4 Speed Cam Shaft [Re: 383man] #1534719
11/19/13 05:37 PM
11/19/13 05:37 PM
South Dakota
Pa karp Offline OP
Pa karp  Offline OP
South Dakota
I am rebuilding the engine to run on pump gas. It will have about 9.3 to 1 compression. I can get a '69 cam shaft, but would like to run one similar to the '68.
The car new ran 14:50's. It may see the drag strip once in awhile, but mainly will be a occasional driver.
Curt Rees
Re: 68 340 4 Speed Cam Shaft [Re: Pa karp] #1534720
11/19/13 05:52 PM
11/19/13 05:52 PM
P
Paul_Fancsali Offline
P
Racer brown can custom grind one last I heard and your right that cam is a great runner and will out perform even the Hemi grind 474 lift by having more low end
Re: 68 340 4 Speed Cam Shaft [Re: Paul_Fancsali] #1534721
11/19/13 08:58 PM
11/19/13 08:58 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Speed Pro CS1019R, 288 intake/ 298 exhaust advertised duration, duration at .050 is 214 intake/ 224 exhaust, lift is .443 intake .465 exhaust, lobe center line is 112. Slightly lumpy idle and runs like a mofo in a 9 to 1 360 with stock heads. Pulls hard from idle to 6000.
Re: 68 340 4 Speed Cam Shaft [Re: elmor353] #1534722
11/20/13 06:36 PM
11/20/13 06:36 PM
South Dakota
Pa karp Offline OP
Pa karp  Offline OP
South Dakota
I ordered a CS1019R cam with lifters today. I think this should work very well with my 4 speed, 3:91 gear.
Thanks for the help! The project continues!
Curt Rees
