O2 sensor/cat converter/stumbling question. 2005 Ram
#1534615
11/18/13 12:53 AM
11/18/13 12:53 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Truck acting up lately. Hesitation on acceleration.
Has the following code.
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
Listed as the O2 sensor after the cat converter. I looked up the sensor on RockAuto and they show 2 sensors. Upstream and Downstream positions.
Would I be looking for the downstream sensor, seeing as how it is after the cat converter?
In the past I have had faulty O2 sensors on other vehicles, and driveabilty usually isn't affected. Hopefully it's this simple.
05 Hemi Ram with 130000km.
Thanks codfish
Re: O2 sensor question. 2005 Ram
[Re: codfish]
#1534617
11/18/13 02:10 AM
11/18/13 02:10 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Bank 1 sensor 2 means its the bank where the #1 cylinder is and the 2 is the downstream as you are correct on that. So on a V8 Dodge it would be the downstream sensor on the drivers side. Also check for any bad connection as a high voltage code can be caused by a bad connection in the circuit. Ron
[Re: Mass_Mopar]
#1534620
11/18/13 04:49 PM
11/18/13 04:49 PM
codfish
Newfoundland
Good to know. ![](/ubbthreads/images/graemlins/thumbs.gif) I replaced the "downstream" sensor and unhooked the battery to clear the code. No more code or light showing and the first short drive seemed fine. So far so good. I got a 7 hour drive tomorrow so we'll see how it goes. Thanks codfish
[Re: Dcuda69]
#1534622
11/19/13 10:22 PM
11/19/13 10:22 PM
codfish
Newfoundland
So. This morning I let the truck warm up for maybe 5 mins before I left on my 7 hour drive across the province. Worked flawlessly. Got to my destination, shut it down and went inside. about 3 hours later, started it up, and drove off. Once again, truck started to hesitate heavily while going up a short but somewhat steep hill. Check engine light flashed on and off this time. ![](/ubbthreads/images/graemlins/confused.gif) . I couldn't stop where I was due to traffic, so I drove to the nearest parking lot. (truck drove fine once the check engine light stopped blinking). I turned the truck off, and checked for any codes by turning the key ahead 3 times in 5 seconds. No codes showing ![](/ubbthreads/images/graemlins/shruggy.gif) . Hmmm. Started it up, ran a few errands and drove back to the house. Seems to act better once it's up to operating temps. Tomorrow morn I will warm it up good before I drive it to see if it makes a difference. Any ideas or educated guess?? Wife wants me to trade it in. I don't want to, but............. codfish ![](/ubbthreads/images/graemlins/drinking.gif)
[Re: codfish]
#1534623
11/19/13 10:28 PM
11/19/13 10:28 PM
Posts: 8,413 Highland, MI.
Sunroofcuda
Highland, MI.
Maybe the catalytic converter is going bad??? That O2 after the cat monitors the cat. Is the converter overheating (glowing red at full heat) or rattling on a cold start?
[Re: codfish]
#1534629
11/20/13 10:39 AM
11/20/13 10:39 AM
codfish
Newfoundland
And of course the truck has 2 of everything (upstream and downstream O2 sensors and 2 cat converters.) ![](/ubbthreads/images/graemlins/hammer.gif) So will checking the temps of the converters help with finding out which one is going bad? I do have a digital temp gun. Just doing alot of reading on the subject and the symptoms of a faulty cat converter sure do match with what I'm experiencing. codfish
[Re: codfish]
#1534630
11/20/13 05:01 PM
11/20/13 05:01 PM
Sunroofcuda
Highland, MI.
If the substrate inside the cat(s) goes bad - they can break-up or get loose. It's not unusual for the padding around the brick to fail & then the brick gets loose inside - sometimes they can even turn sideways & block exhaust flow. I had a '96 Ram with a bad cat & it rattled like heck on a cold start, but then when things heated up, the rattling stopped - it never threw a code though. Dodge replaced it under warranty - the OE cats are covered for 8 years or 100,000 miles federal law. When the truck is cold, get under it & put a glove on & bang on the cats & see if one of them rattles inside. If it does, the brick is loose & it needs replacing.
