Re: SEMA and the SB Victor 16 heads
[Re: SpareParts]
#1532965
11/13/13 11:25 PM
11/13/13 11:25 PM
Posts: 3,429 Toronto
mshred
Toronto
I asked a rep about them. He told me to check the internet.... very helpful.....
very ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: J_BODY]
#1532967
11/14/13 07:06 AM
11/14/13 07:06 AM
Posts: 27,486 So Cal
autoxcuda
So Cal
[Re: justinp61]
#1532971
11/14/13 06:26 PM
11/14/13 06:26 PM
mshred
Toronto
Some detail pictures here:
https://board.moparts.org/ubbthreads/show...rue#Post7913610
And from the pictures that have been posted above for it, I have to say that Edelbrock apparently took making one new SBM Victor head a lot more seriously than they did w/ their BBM Victor head...
Fixed
lol
Yea, I have seen the other thread, just wondering if anyone got anymore information on the heads other than what was on the placards on the stands they were on like a release date or price?
[Re: pittsburghracer]
#1532973
11/14/13 07:02 PM
11/14/13 07:02 PM
mshred
Toronto
Between the different valve angle and the 2.15 intake valve size i thing sales will be low if they ever do come out.
true I guess as a bolt on deal...but maybe not if you are building a motor around them
[Re: SCATPACK 1]
#1532975
11/14/13 07:11 PM
11/14/13 07:11 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Sounds like Edelbrock had some rent a reps (like rent a cops) for special events coverage. And the guy was obviously un-educated about anything not shivy related. Hey just sayin... call it like it is.
I met him at a chassis shop a few miles down the road, he was driving a Silverado with the Edelbrock supercharger kit, fancy jacket and shirt, watch, the whole 9 yards. Maybe he just didn't know about them ![](/ubbthreads/images/graemlins/shruggy.gif)
#1532977
11/14/13 07:46 PM
11/14/13 07:46 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Custom pistons would be your only option and valve to bore ratio kinda leans toward an aftermarket block with a big bore. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) If that's the case why not go W8 or W9.
Because these will fit on a 59 degree block, use commercially available headers, and appear to use single shaft rockers.
The price of a custom piston upgrade is a drop in the bucket compared to needing headers built, 48 degree block, and T&D rockers.
The problem is that there really doesn't need to be any better 59 degree heads until someone builds an affordable block to go with it.
[Re: dizuster]
#1532978
11/14/13 07:56 PM
11/14/13 07:56 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
We have a winner!
[Re: dizuster]
#1532979
11/14/13 08:00 PM
11/14/13 08:00 PM
Posts: 20,206 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Valve to bore size.
VALVE / BORE Ratio
The valve to bore ratio should be: 52-52.5% of the bore for Wedge heads. 53-53.5% for Canted valve, rotated canted valve (Mopar P/S hemi) and true Hemi. If you decrease intake exhaust ratio down to 70-71% you can move both intake and exhaust valves over to the exhaust side and increase intake valve size by .5-1%.
Anytime you increase valve size over the above stated Valve/Bore ratio you will see a small gain in CFM but the discharge coefficient drops and takes your power with it. An over shrouded valve instills a host of nasty scenario's, the two worst being decreased discharge coefficient and increased reversion below and above intake tuned power band. (according to Darin Morgan)
#1532980
11/14/13 08:42 PM
11/14/13 08:42 PM
mshred
Toronto
True
[Re: dizuster]
#1532981
11/14/13 08:42 PM
11/14/13 08:42 PM
mshred
Toronto
And even truer
