Tips for SS Spring Drag Cars
#15309
04/29/05 03:31 PM
04/29/05 03:31 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
FRONT SHOCKS I have used adjustable shocks, but the stock ones seem to work the best. TORSION BARS I have used different sizes. Have used MP Drag bars an even tried turning a set down on the lathe. Stock slant 6, stock 318 bars. The Drag bars worked ok, but they did not seem to last very long. Were always cranking them back up because they would lose there strength. The stock 318 bars have seemed to work the best. Torsion bars have a front an back an left an right. Need to make sure they are installed correctly. (Popular Hot Rodding March 2002 pgs 66-70) all about T-bars. SUPER STOCK SPRINGS You have to have the correct weighted rated spring, for the weight of your car. My car weighs 3700 lbs. I use 3800lb rated springs. MP #312-P3690454 R #312-P3690455 L Don’t take out or ad leafs to the springs! SPRING CLAMPS Do not take off the factory clamps. I have added clamps to the first segment of leafs in front of the axel on BOTH sides. I Also have added clamps on the first segment of leafs after the axel on BOTH sides. An have added one clamp on the drivers side, in front of the factory clamp towards the rear of the spring. You will have to make sure that these will not get in the way with your tires. I have had to grind on the springs to get clearance. They will need to be checked often because they will move around. REAR SHACKEL Do not change the location hole of the shackle. I use the factory shackles. PINION ANGLE I have used the shims that are installed between the axel an springs they worked fine. I have now welded my rear end to 7*. REAR SHOCKS You have got to have a rear shock that extends further than the body travels! If you have a shock that is to short the car will unload the tires, leaf springs will open to quick an it will spin. I have used many different shocks. 2 sets of adjustable Comps., adjustable Ranchos, original factory shocks, an many truck shocks. I have even tested shocks on a shock dyno. I see no gains with any of the adjustable shocks NONE. The best shock that worked for me was ones made for heavy trucks. Before installing shocks compress both at the same time, a release them at the same time. The one that comes up the slowest is now the RIGHT rear shock. RAKE You need to have some rake in the car. I have around 2”. I measure this on the frame directly behind the front wheel, an on the frame directly in the front of the rear tire. TIRE PRESSURE I have to stagger tire pressure. I stagger mine with a 1/2lb more in the right rear. Some cars we have worked on require more than a 1/2lb of stagger. I have found that if the tire pressure is the same in both tires it will drive to the right every time.
These tips may not work for you. This is what I have done to mine, an I can 60’ low 1.40s on the back tires off an idle.
Shawn Jennings
Re: Tips for SS Spring Drag Cars
[Re: rt66jim]
#15314
04/29/05 04:37 PM
04/29/05 04:37 PM
572_dup2
Salina ks
MP shocks would work pretty good on your screen door, not in a race car. My shocks are gas.
Shawn Jennings
[Re: tazmaniac]
#15318
04/30/05 10:48 PM
04/30/05 10:48 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I switched to the 002/003with a 1/2 leaf on the passenger side, from the beefy SS springs in my Charger, havent test yet but from advice from Chuck Lofgren he said for a starting point passenger side one clamp right at the 1-2 leaf next to the hanger and one on the 2-3 leaf,driver side one clamp 1-2 leaf next to the shackle and a clamp on the 2-3, also about a 2-3 degree rake, level the car with the TB which will pre load the right rear because of the 1/2 leaf, 7 degrees pinion angle and a proper front end alignment
Ok I am trying to understand this..I am not to bright sometimes LOL..#1 spring is the main leaf or bottom leaf ? and hanger is that the front or the shackel in the back ? and does the 1/2 leaf on the passenger side toward the back or front ? Thanks...:)
[Re: 572_dup2]
#15319
04/30/05 11:01 PM
04/30/05 11:01 PM
Posts: 815 Alexandria, NJ
WayneM
Alexandria, NJ
Nice post, Shawn! What about snubbers? use one or not? if so, what kinda space or preload? Is that a Dodge truck rear shock? Possible to get a part number? What rear tire do you run on that car? What front alignment specs?
2014 Durango R/T 2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed 1998 Dodge Durango SLT 5.2 1971 Plymouth Duster- <<<<<MOPAR SPOKEN HERE>>>>>
[Re: Ari440]
#15322
04/30/05 11:59 PM
04/30/05 11:59 PM
Posts: 5,618 long island NY
Ari440
long island NY
572 do you use the aluminum bushing in the front spring eye
1.39 9.85 - 137 mph
[Re: tazmaniac]
#15324
05/01/05 02:11 AM
05/01/05 02:11 AM
572_dup2
Salina ks
No pinion snubber.
I dont use a 2001 Dodge 3/4 shocks. They work good on a Dart. Mine are gas shocks.
13.5" Phoenix with tubes.
I do my own front end alignment.
I use aluminum front eye bushings.
tazmaniac is right on!
Shawn Jennings
[Re: 572_dup2]
#15326
05/02/05 01:55 AM
05/02/05 01:55 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
How would a early B-body load leveler shock work on an A-Body Cuda. The type with a spring over the shock. Jesse Quote:
No pinion snubber.
[Re: 68Fastback]
#15328
05/03/05 09:06 PM
05/03/05 09:06 PM
572_dup2
Salina ks
what is a load leveler shock?
Shawn Jennings
