Re: Odd /6 problem [Re: SattyNoCar] #1532064
11/12/13 12:38 PM
11/12/13 12:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
What carb/intake are you using? You don't happen to have one of the 2 piece welded intakes do you?
Was the head or block decked much? If so the intake may not be sealing against the head. When you deck the block there is a casting block that will hold the intake away from the head.
From that pic with the head off it looks pig rich. I have seen that caused by vacuum leaks before.
Re: Odd /6 problem [Re: slantzilla] #1532065
11/12/13 01:37 PM
11/12/13 01:37 PM
Buzzardbreath Wyoming
BigBird Offline OP
BigBird  Offline OP
Carb is a Holley 1945. Intake is stock. Deck and head were milled just enough to make it flat. Probably less than 20 thou. It is running really rich but mostly due to the amount of cold starts. It hasn't been warmed up properly for a while. I'm leaning towards a vacuum leak being the issue but I'll change the carb again and see if I get better results.
Re: Odd /6 problem [Re: BigBird] #1532066
11/12/13 01:40 PM
11/12/13 01:40 PM
Alberta
rustbuckett68 Offline
Alberta
Just a thought, but did you check for TDC? Maybe the crank gear key sheared.
Re: Odd /6 problem [Re: rustbuckett68] #1532067
11/12/13 02:03 PM
11/12/13 02:03 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Fouled plugs don't "unfoul" themselves, and they also create carbon hotspots which screw up cylinder firing. so if you are doing all of this diagnostic work with fouled plugs, you're wasting your time
the other thing I notice is the exhaust pipe flange. it looks like the entire thing has been leaking. slant sixes are very sensitive to exhaust leaks because they are small engines and already dialed in to be very lean. that could certainly cause popping.
Make sure the heat riser valve in the exhaust manifold isn't frozen shut. that'd make it run like a dog
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Odd /6 problem [Re: VincentVega] #1532068
11/12/13 03:02 PM
11/12/13 03:02 PM
BigBird Offline OP
BigBird  Offline OP
Installed a brand new set of plugs 2 days ago. Exhaust is only tack welded together so a leak at the manifold flange shouldn't have changed how it runs just recently. The riser is free and even pulled the EGR and cleaned it.
Re: Odd /6 problem [Re: BigBird] #1532069
11/12/13 03:10 PM
11/12/13 03:10 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You have fuel, compression on all 6, spark, it should run if the fuel and spark are right. You have no vacuum leaks. Compression rules out bad cam lobes, valves, timing chains and head gaskets. Two different carbs rule out fuel, unless they are both bad.
Must be an ignition problem of when it ignites. Is the mechanical advance working? Try timing it by ear instead of a light. Could be a bad light or slipped damper ring giving a bad reading.
Re: Odd /6 problem [Re: BigBird] #1532070
11/12/13 03:13 PM
11/12/13 03:13 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
My bet is on the valve lash. Maybe an exhaust seat is pounded out or if too much material was taken off of the head ?
Re: Odd /6 problem [Re: drew72] #1532071
11/12/13 08:40 PM
11/12/13 08:40 PM
BigBird Offline OP
BigBird  Offline OP
The head is off and I can see the valves and seats. They look good. Can't get it to run well enough to even tune it by ear. Like I say it has me stumped. The compression test should have shown a bad valve. I'll give it another carb change and see if that does it when I get the head back on.
Re: Odd /6 problem [Re: BigBird] #1532072
11/12/13 08:51 PM
11/12/13 08:51 PM
I doubt if you have one laying around but I'd wanna swap the intake manifolds. After all this I would have to know what it was all along no matter what the cost
Re: Odd /6 problem [Re: RapidRobert] #1532073
11/13/13 09:55 AM
11/13/13 09:55 AM
BigBird Offline OP
BigBird  Offline OP
You don't know the kind of pack rat I am. I do have another intake laying around and I think I'll try it when I put the head back on. That is one thing I haven't tried yet.
Re: Odd /6 problem [Re: BigBird] #1532074
11/13/13 09:05 PM
11/13/13 09:05 PM
BigBird Offline OP
BigBird  Offline OP
Installed the new head gasket and blocked off the EGR port. It runs like a champ again. Was it the head gasket? Was it the EGR? I don't know but it runs good again. Feel much better about it. The head gasket looked good enough to reuse so I don't think that was it but the new one I torqued tighter than the specs ask for thinking it might have been leaking across.
Re: Odd /6 problem [Re: BigBird] #1532075
11/14/13 04:51 AM
11/14/13 04:51 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If the EGR was stuck open it would run like crap.
Glad to hear all is well again.
Re: Odd /6 problem [Re: BigBird] #1532076
11/14/13 11:13 AM
11/14/13 11:13 AM
Was it the EGR?
If it was leaking (I had one that did) it'd be a massive vac leak
Re: Odd /6 problem [Re: RapidRobert] #1532077
11/14/13 11:18 PM
11/14/13 11:18 PM
BigBird Offline OP
BigBird  Offline OP
Very well could have been the problem all along. I hate anything to do with emissions. It certainly caused me several days of extra work and head scratching. It is nice to be able to move it around under of it's own power again.
Re: Odd /6 problem [Re: BigBird] #1532078
11/15/13 02:05 AM
11/15/13 02:05 AM
Success! Just me I'd undo the EGR & see if it acts up just like it did before . You could do it & reverse it in no time. After all this I would HAVE to know for sure
Re: Odd /6 problem [Re: RapidRobert] #1532079
11/15/13 10:33 AM
11/15/13 10:33 AM
BigBird Offline OP
BigBird  Offline OP
I've got a bunch of work to get caught up in the shop first but I probably will try that to settle it in my mind as well. I still have to put all the things I took apart on the darn thing back like they should be before I can drive it out to clean up my mess. This delayed the tranny rebuild by a month and I had hoped to have the interior painted but it is good to have it running again. My son will be driving this spring and I plan on having it completed so he can drive this. I do think it was a good learning tool for him also. We did a lot of trouble shooting that is not normally done.
Re: Odd /6 problem [Re: BigBird] #1532080
11/15/13 11:34 AM
11/15/13 11:34 AM
No doubt about that & this hobby will sharpen a persons' diagnostic skills/related thought processes & raise your tolerance level for frustration
Re: Odd /6 problem [Re: RapidRobert] #1532081
11/15/13 11:46 AM
11/15/13 11:46 AM
BigBird Offline OP
BigBird  Offline OP
That is one of the things I keep telling him. He needs to know the basics on how it all works instead of just plugging it into a machine and replace the parts that it tell you to. Anyone can change parts but fewer guys anymore can work their way through the process of finding what's wrong the old way. Under all the electronics is still a mechanical base.
Re: Odd /6 problem [Re: BigBird] #1532082
11/16/13 12:06 PM
11/16/13 12:06 PM
I had forgotten all about that EGR valve on the outside (pass) side of the ex manifold. I swapped 1 /6 30 years ago & hit the EGR valve during the install & partly unseated it & from my verbal descrip of how it was acting a chrysler dealership mechanic immediately knew what it was
Re: Odd /6 problem [Re: RapidRobert] #1532083
11/16/13 12:15 PM
11/16/13 12:15 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Was it the EGR?
2 things cause a backfire through the carb, lean condition or fire while an intake valve is still open.
Bad EGR can cause a lean condition.
Glad you got her fixed.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
