Odd /6 problem
#1532044
11/11/13 01:54 PM
11/11/13 01:54 PM
Posts: 1,279 Buzzardbreath Wyoming
BigBird
I have a /6 installed in a rat truck we are building for my son. The engine has a fresh overhaul and ran sweet as could be until about a month ago. It started running like the timing had jumped a tooth on the timing chain. We pulled the timing cover and it was all ok and timed correct on the chain. The pin was still intact on the cam and was solid. We pulled it off to double check. We changed the carb to a different one. We switched the plug wires, coil, rotor and cap for new ones. We installed a petronics electronic ignition. We have check for vacuum leaks and found none. It still backfires through the carb and is hard to start. The wires are installed correct with #1 cylinder one top dead center with the rotor at #1. The firing order is correct 153624. The compression is good on all cylinders and the cam seems to be operating correct as the rockers are all going up and down. I'm stumped and a couple of friends have all been stumped as well. A /6 should be a no brainer to make run but it has me scratching my head. Any ideas?
Re: Odd /6 problem
[Re: BigBird]
#1532045
11/11/13 01:57 PM
11/11/13 01:57 PM
RapidRobert
IGN! Put the points or MP electronic dizzy back in & see what happens
Re: Odd /6 problem
[Re: BigBird]
#1532047
11/11/13 03:12 PM
11/11/13 03:12 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Pull the distributor.Ill bet the gear is going or gone.I bought a /6 Volare wagon for 25 bucks a few years ago for pretty much the same thing.The gear on the dist was shot.Quick trip to a buddys junk yard and a free dist and it was like new.Rocky
Chrysler Firepower
Re: Odd /6 problem
[Re: BigBird]
#1532049
11/11/13 03:25 PM
11/11/13 03:25 PM
therocks
Niles , Ohio
Its not so much they are intact but they wear.Like a speedo gear that wont turn.The teeth wear donw and dont engage right.They used to sell a repair kit.It was cheap if still avaliable.Is this an older model with solids?Id pull the valve cover and check lift and do a compression check.Rocky
Chrysler Firepower
Re: Odd /6 problem
[Re: B5 Bee]
#1532051
11/11/13 04:25 PM
11/11/13 04:25 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Did you lose any cam lobes?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Odd /6 problem
[Re: VincentVega]
#1532052
11/11/13 05:11 PM
11/11/13 05:11 PM
RapidRobert
When you checked for vac leaks you sprayed all around the intake top to bottom/end to end & no change?
Re: Odd /6 problem
[Re: RapidRobert]
#1532053
11/11/13 06:36 PM
11/11/13 06:36 PM
BigBird
Cam lobes look ok. Lifters show no odd wear and rocker shaft was opening the valves ok. Sprayed starting fluid all over the intake and carb base with no sign of vacuum leaks. Put a new carb gasket under the carb. Just pulled the head and the gasket looked fine. The valves all look good and open and close when tapped with a small hammer on the stem. I ordered a new head gasket to reinstall the head. 5 cylinders showed 125 psi and 1 showed 115. Back fires through the carb like timing is way off. Distributor was a new point one with a brand new gear.
Re: Odd /6 problem
[Re: BigBird]
#1532054
11/11/13 06:45 PM
11/11/13 06:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Check your coil wire, had a customer come in with issues similar to yours, after he mangled up the distributor drive gear by "adjusting the the point" on his 78 pickup (he had electronic ignition) and taking out his distributor drive gear I found his original problem, the center core of the coil wire had eroded back about 1/2" into the insulator.
Re: Odd /6 problem
[Re: RapidRobert]
#1532057
11/11/13 10:11 PM
11/11/13 10:11 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
How does it run after getting it started? Will it rev freely or start to rev then seem to lose power? Been a while but I worked on a /6 Duster w/ almost the same symptoms, IIRC. Turned out the muffler had come apart and was blocking the tail pipe.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Odd /6 problem
[Re: RapidRobert]
#1532058
11/11/13 11:20 PM
11/11/13 11:20 PM
BigBird
I agree. I'm stumped. A /6 should be the most simple to figure out and make run. Vacuum leak would have to be pretty big to act like it does and therefore should be no problem to find but it evades me. Like I said the head is now off and waiting on a new gasket. Napa says the closest is in Indiana. Who would have thought a head gasket for a six would be that scarce. when it does start it is really low on power and won't pull it's self like a jumped timing chain. The exhaust is a straight shot to just behind the cab.
Re: Odd /6 problem
[Re: BigBird]
#1532061
11/12/13 04:58 AM
11/12/13 04:58 AM
Posts: 20,166 Park Forest, IL
slantzilla
Park Forest, IL
Did the head have the valves redone? On a hydraulic motor the stems have to be very close to the same height and you have to have the correct preload or they can hang valves open after the lifters pump up. The iron gear from NAPA is discontinued. I just had a buddy do a national search. The part number is still good, but all 6 boxes we got had nylon gears in them. FWIW, I have destroyed a lot of stuff racing Slants, but the only time I ever broke a distributor gear was when I got in a hurry putting the distributor back in and jammed it onto a tooth on tbe cam gear. They really are fairly tough.
Re: Odd /6 problem
[Re: BigBird]
#1532063
11/12/13 10:57 AM
11/12/13 10:57 AM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
Sorry, nothing to add, just watching this thread with curiosity as I had a slant sick from hell about 20 yrs ago. In my case, it was a low mileage '79 Dodge PU, stone stock. Ran great....for the first two days I owned it. After that, it wouldn't run/drive more than 50 ft at a time. Hot or cold, engine had good, even compression, good vacuum. I basically ended up swapping EVERYTHING either on or around the engine, and it made no difference. With the help of a friend, I even ran the engine totally separate from ANY of the truck's control (as if the engine were on a test stand). NOTHING made a difference. Ended up scrapping the truck out of disgust. I hope you have better luck.
John
