Re: 340 Resto Block Issues - Engine Mounts - Help!
[Re: Paul_Fancsali]
#1531710
11/11/13 01:52 PM
11/11/13 01:52 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have 340 mounts (no fit) aren't 67-72 318/360 mounts (the steel brackets) the same?
[Re: ScottSmith_Harms]
#1531711
11/11/13 03:05 PM
11/11/13 03:05 PM
Posts: 2,578 sweden
1Fast340
sweden
the mounts on the block are different with on the driverside for some weird reason while passangerside they are all the same.
273/318 has a wider bracket
340/360 has a narrow version from my memory. seems like the only mounts/brackets for the later spoolmount system that can be found in partsstores is the wider 273/318 version and with 318 being the most common engine it sort of makes sence,since a simple nut or a few washers can be used as a spacer to make the wider brackets fit the narrow mounts on the 340/360block.
[Re: 1Fast340]
#1531712
11/11/13 08:59 PM
11/11/13 08:59 PM
Posts: 660 River Falls, WI
urdustd
River Falls, WI
Exactly what I was trying to get to
[Re: Joesixpack]
#1531717
11/11/13 10:59 PM
11/11/13 10:59 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
YOU HAVE B/E MOUNTS PICTURED TRYING TO ATTACH TO YOUR BLOCK,THEY WOTN WORK WITH A-BODY, STEELS AND RUBBERS ARE DIFFERENT.
Correct on that. If going into an A body car, those brackets won't work anyway.
The block having the high hole position at rear is going to be an issue with most 273/318 mounts which is what you need, not 340/360 mounts.
I have a mount bracket that will work with the high mount hole. $30 + shipping
[Re: B G Racing]
#1531721
11/24/13 12:52 PM
11/24/13 12:52 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If you use the correct mounts and insulaters they work fine.We done many resto blocks and never had an issue with the block bosses.Keep in mind the mounts must be the correct ones for the K-member as well.
Bob, "correct mounts"? Which correct mounts are you referring to? I have several original 340 engines here for reference, as well as the Resto block. The blocks are not the same, the drivers side mounting boss is different on the Resto block so the "correct" E-body 340 mounts I have do not fit it. I realize that the different K-frames require different mounts, what I'm trying to determine is which mounts fit the resto block (which factory mounts from which year and engine combo will work on this block, in my case, for a 71 A-body). So, I have 70 E-body 340 mounts and they won't fit the block, I also have some A-body 67-72 318 mounts, which are the right width but the hole on the rear lug of the drivers side is too low so they don't fit either.
What cars/engine combos came with the drivers side mount that had the high mount hole mentioned a few posts above?
#1531725
11/25/13 01:01 AM
11/25/13 01:01 AM
dartman366
Mt. Vernon, Ohio
This is the bracket I just received (supposed to be a drivers side 67-72 273-318 mount).
Ok, when you said lug I was thinking the lug on the block was too low,,nevermind
[Re: B G Racing]
#1531727
11/25/13 11:34 AM
11/25/13 11:34 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
Get some flat stock and weld a new ear to that bracket to match the lug on the block. Very easy to do.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1531728
11/25/13 11:40 AM
11/25/13 11:40 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure, always an options as a last resort, but with all of the posts on this thread that say "Oh no problem, just use "X" mounts, they work fine" I'd rather find one of those and bolt it on.
#1531729
11/25/13 11:49 AM
11/25/13 11:49 AM
Posts: 16,189 Mesa, Arizona
dart4forte
Mesa, Arizona
What about the driver side bracket for a poly?
