lifter mixup gaffe #1531328
11/10/13 06:47 PM
11/10/13 06:47 PM
RapidRobert Offline OP
SB hyd race cam. I accidentally mixed up the order of (2) of the lifters . Should I go ahead & reinstall everything (50-50 chance) or rebreak it in with 2 new lifters? Thank you for your time.
Re: lifter mixup gaffe [Re: RapidRobert] #1531329
11/10/13 06:57 PM
11/10/13 06:57 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
How much run time?
Re: lifter mixup gaffe [Re: HairOtheDog] #1531330
11/10/13 07:03 PM
11/10/13 07:03 PM
Substantial
Re: lifter mixup gaffe [Re: RapidRobert] #1531331
11/10/13 07:04 PM
11/10/13 07:04 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
with my luck , the 2 new lifters would fail... still the best way to go .
Re: lifter mixup gaffe [Re: RapidRobert] #1531332
11/10/13 07:04 PM
11/10/13 07:04 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
If they both have nice crowns on them .., not to worry .., stick em in there
Re: lifter mixup gaffe [Re: dOc !] #1531333
11/10/13 07:06 PM
11/10/13 07:06 PM
rock em end to end to see if there is still a crown on both of em?
Re: lifter mixup gaffe [Re: RapidRobert] #1531334
11/10/13 07:41 PM
11/10/13 07:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
yep. were they a quality lifter in the first place? when you look down the bore is there anything that might cause concern? this is probably a case of over-thinking/stressing since they have been together and matched to the cam since new.
Re: lifter mixup gaffe [Re: RapidRobert] #1531335
11/10/13 07:46 PM
11/10/13 07:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
For the cost of what, $10.00 a lifter, you are going to take a chance on wiping the cam out? You can't be serious.
Re: lifter mixup gaffe [Re: 6PakBee] #1531336
11/10/13 08:31 PM
11/10/13 08:31 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Not my area of expertise, but I have heard of guys swapping lifters around despite strong suggestions against it.
Dwayne Porter is regarded as a G U R U with Mopar stuff and when I asked him about this very thing several months ago, he was on the fence about it. I asked him about when an engine was broken in then a cam change was considered, are new lifters mandatory. He said that he had reused lifters on a different cam with no bad results. He didn't suggest it outright but said that he had done it before.
Maybe a teardown for an engine builder isn't that big of a deal, but to a regular guy that builds maybe one engine every 3 years, it is a different story.
After 3 cam failures in 2 engines in the last 7 years, I tend to be cautious. Personally, I'd put in new lifters.
Re: lifter mixup gaffe [Re: RapidRobert] #1531337
11/10/13 09:19 PM
11/10/13 09:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
More than likely even if mixed up it will be alright just as long as all lifters are in good shape.
I guess a couple new one's would be less risky? But I'm not so sure on that?
I use some 4X4" blocks of wood to keep lifters in.
Push rods for a BAE hemi.
Then I have some custom made. Sometimes I have had more than one motor apart at a time, got to be organized. These are too small for BAE hemi parts.
Re: lifter mixup gaffe [Re: Challenger 1] #1531338
11/10/13 09:29 PM
11/10/13 09:29 PM
After 6pakbee implying that I might be an idiot on this deal I am rather embarrassed to admit that I just realized that I have 2 new extra lifters on hand for another new cam/lifter set that I bought awhile back as I thought I lost 2 then I found them after I bought the 2 new ones . Thanks guys
Re: lifter mixup gaffe [Re: RapidRobert] #1531339
11/10/13 10:04 PM
11/10/13 10:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Robert, I in no way was trying to imply you were an idiot. I have always found your posts very useful and informative. I was more surprised (shocked?)than anything else by the question. Glad you found two new lifters!
BTW, it doesn't matter which of the two empty lifter bores the new lifters go in.
Re: lifter mixup gaffe [Re: 6PakBee] #1531340
11/10/13 10:10 PM
11/10/13 10:10 PM
Hey bro that was a bit harsh of me & I humbly apologise. What happened was I pulled the 2 lifters out of cyl #1 thinking that they were 2 junk ones that I had locked solid & had in there for degreeing purposes forgetting that the day before I had put the 2 good ones back in there. As soon as I tossed em on the towel on the bench & they rolled together I realized what I had done
Re: lifter mixup gaffe [Re: RapidRobert] #1531341
11/11/13 12:12 PM
11/11/13 12:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think, and this is just guess work, that the success rate of reusing used lifters in other bores depends a lot on valve spring pressures. A mild cam probably will work, a serious cam, probably not going to last.
Don't be the exception.
