Engine coolant in my transmission
#1531040
11/09/13 10:21 PM
11/09/13 10:21 PM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
My '96 Ram 1500 got a new radiator a year ago, after the last one crapped out. Recently I noticed the temp gauge going past the normal area. After parking, and cooling down I topped up my radiator with coolant. Almost immediately my automatic transmission started acting poorly. I parked it for a month while I worked away from home. I came back to find a puddle of transmission fluid and coolant together under my truck's transmission. So I know what the problem is, the transmission cooler and radiator are leaking together. The question is: If I flush the transmission after I put the new rad in, will the trans be alright having had water circulating through it?
Re: Engine coolant in my transmission
[Re: Pacnorthcuda]
#1531044
11/09/13 11:48 PM
11/09/13 11:48 PM
Posts: 404 Central New York
bfury
Central New York
The tranny coolant tube in the bottom of the radiator has a leak.Drain the radiator and the tranny. Disconnect the cooling lines from the tranny to the radiator and put in a separate cooler. Drain and flush the tranny including the converter. If you are lucky everything will be fine. Change the tranny fluid and filter again after a hundred or so miles if it works. Oh and plug the fittings in the bottom of the radiator for the trans fluid lines.
No Stock
[Re: bfury]
#1531045
11/10/13 11:06 AM
11/10/13 11:06 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Change it as said.Then after fluid and filter add a can of Transfusion.Drive for say 100 miles and do the same thing.I had a few at work that had the same problem.One was still going strong 4 years later.Its a crap shoot but its cheaper than a trans.Rocky
Chrysler Firepower
[Re: magnumcharger]
#1531047
11/10/13 01:43 PM
11/10/13 01:43 PM
Posts: 21,526 It's a dry heat
gtx6970
It's a dry heat
Not likely. chances are a trans overhaul is in it's very near future. Clutch plates and bands don't get along well with engine coolant
[Re: magnumcharger]
#1531048
11/10/13 02:38 PM
11/10/13 02:38 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I see you are in Canada. Does the highway department in your area use calcium chloride on the roads? A friend had a diesel pusher motor home that he took to Alaska in the summer. When he got back he had to replace the rear mounted radiator at a cost of thousands. Seems the calcium chloride attacks aluminum and rear mounted radiators get all the dust kicked up by the tires and it settles in the radiator and starts to eat. Have you driven in dusty conditions and not rinsed afterwards? Something to think about after your trans rebuild and another new radiator ![](/ubbthreads/images/graemlins/frowwn.gif)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1531049
11/10/13 03:39 PM
11/10/13 03:39 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not a likely culprit. Cloride would have attacked the external cooler lines - not the internal where the leak would have to be. I would still try the major flushes and a prayer. Have seen many older transmissions live a long happy life if when caught early.
[Re: MoparforLife]
#1531050
12/30/13 10:21 PM
12/30/13 10:21 PM
magnumcharger
So, I replaced the radiator, then flushed the transmission, and replaced the filter. I took the truck for a test drive. It seemed to work great! Then... I got home, and noticed water seeping out of the front of the engine, and transmission fluid dripping from the back of the transmission pan. I assumed that the thermostat was leaking. I had a new thermostat and gasket, which I installed. The trans oil pan had a small rust hole in the back. So I removed the pan, draining the trans yet again. I noticed a few clutch linings in the drip tray... I sandblasted the pan, and welded up the hole. I replaced the fluid and gasket, reinstalled the pan, then took it for another test drive. This time it told the tale: it wouldn't shift, it revved like it was in neutral, and when it finally shifted, it banged into gear. All of the sudden the transmission was toast. Okay. I got back to my house and the engine disgorged all of its coolant out of the front of the block, behind the pulleys. So, waterpump as well. I bought a waterpump and tossed it on the front seat, I'll install it next spring. The transmission will have to be rebuilt. Meanwhile...I bought a 2014 RAM Laramie. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: magnumcharger]
#1531053
12/31/13 08:31 AM
12/31/13 08:31 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Wow!....you still went and bought another Dodge Ram!, I'm all done with Dodge Rams, after numerous transmission failures/replacements in every Dodge Ram I've owned, countless 4X4 hubs/untold ball joint replacement, along with repeated suspension failures, codes, PCMs, seemingly all inherent in the Dodge Ram line up from 94 to present,...after this one dies, no more Dodge Rams for me, great lookin trucks, but that's all they got, makes owning a Ford seem appealing
[Re: DAYCLONA]
#1531054
12/31/13 09:23 AM
12/31/13 09:23 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I would never buy a Ford truck. I work on to many of them.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: screamindriver]
#1531056
12/31/13 12:42 PM
12/31/13 12:42 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Local trans shop owner says the Chebbys are the least present customer at his shop...And the mopars keep him in business...
Agreed, my Boss dumped his last Ram 2008 model (which replaced the 2003 Ram after it toasted a tranny) and again another tranny went south, and he tired of it being at the dealer more than driving it...his 2009 GMC to date hasn't had 1 issue, and it doubles as the company plow/tow vehicle
[Re: magnumcharger]
#1531057
12/31/13 04:35 PM
12/31/13 04:35 PM
Posts: 26,027 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've pulled apart a couple of TF's that were contaminated with coolant, in some places the fluid had turned to jelly. A good cleanup is all they needed, no visible damage to anything.
