Re: E-body front suspension question
[Re: 340swing]
#1531011
11/17/13 12:23 PM
11/17/13 12:23 PM
RapidRobert
Any possibility it's the oddball (wrong) Kmember?
[Re: 340swing]
#1531013
11/17/13 01:42 PM
11/17/13 01:42 PM
Posts: 1,567 Ky
jt4406
Ky
Is the mounting bracket that the top of the box bolts to square and undamaged looking? maybe someone ran over something in the road in the past and clipped the drag link/pitman are area and pushed it up there slightly. Should be easy to see with the box removed. Sorry I can't help you with the casting numbers on the box, mine has power steering.
Yeah, it's hopped up to over 160...
[Re: 340swing]
#1531015
11/17/13 01:53 PM
11/17/13 01:53 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Couple of things.Nothing to add about the steering box itself,I had always assumed the car boxes were all dimensionally the same, and had heard that thru 'tribal wisdom' also.I personally have a 'police/taxi'F body one in my '73 chall with zero issues.I will say that raybestos makes NAPA chassis now, and TWO pitman arms had the spline broached too big and it sat too far down on the spline to tighten up. (Maybe yours seated farther down with the new part?) I believe I ended up with MOOG stuff last summer.It worked. K member could have taken a 'whang' somewhere in it's life (that's why some gusset the box mount and someone is making that cool lower bearing support), wouldn't take much of a hit to tweak the idler arm mount, it is only thick sheet metal. On my Clonerunner, previous owner adjusted steering box center screw all the way out, allowing the pitman shaft to move "up" into the box, and begin to consume the header tube, which is kind of where your issue is, too.Part of the clue was the drag link rubbing on the oil pan. Chassis shims are readily available at NAPA, they use various thicknesses for like the early GM 'dogbone' control arms. Hope this helps. Bear
[Re: jt4406]
#1531016
11/17/13 02:01 PM
11/17/13 02:01 PM
Posts: 1,567 Ky
jt4406
Ky
Found this on "For A bodies only" (The early box number is cast behind the LH mounting ear and will be a 2267162 or 2267225 for a bushing type or bearing type respectively. The '67-up box has number 2537349 cast into it on the round section the pitman shaft passes through) No mention of only fitting A bodies. Everywhere else I looked says the boxes are the same for A/B and E bodies.
[Re: jt4406]
#1531018
11/17/13 02:21 PM
11/17/13 02:21 PM
Sixgun
Western Washington
Something knocking around in my head about the A bods only having brass or bronze bushings somewhere inside, and the B s and E s getting bearings.(Maybe Ehrenbergs column at some point) BTW where IS Ehrenberg on all of this?
[Re: Sixgun]
#1531019
11/17/13 03:25 PM
11/17/13 03:25 PM
Posts: 18,157 Mass
DAYCLONA
Mass
If the OP was installing some 73-up (tall) B spindles on his ride, Rick would be all over this post ....
[Re: Sixgun]
#1531020
11/17/13 03:30 PM
11/17/13 03:30 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
As I stated before, 70/1 FPM shows A-body with /6 got the bushed unit. All others got the bearing unit.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1531021
11/17/13 03:44 PM
11/17/13 03:44 PM
Sixgun
Western Washington
Sorry, Marks, missed that... Yes ,you did say that already.
[Re: DAYCLONA]
#1531022
11/17/13 03:46 PM
11/17/13 03:46 PM
Sixgun
Western Washington
And THAT, my friend, is no baloney...
[Re: Sixgun]
#1531023
11/17/13 03:58 PM
11/17/13 03:58 PM
moparmarks
No worries.
