Page 3 of 4 1 2 3 4
Re: E-body front suspension question [Re: jeff968] #1530990
11/15/13 09:48 PM
11/15/13 09:48 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Jeff thanks for the center link. I matched it up with mine and its the same. Yours has a part #2835877. So John I will be calling you, I need an E-body manual steering box. I will update as i figure this out. Thanks for all the help Moparts!
Re: E-body front suspension question [Re: 340swing] #1530991
11/16/13 10:53 AM
11/16/13 10:53 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Looks like a real nice car there. Don't think the M/N parts will be a problem. Doesn't look like a car that's going to see a lot of miles.
BE and A w/ V-8 share that same manual boxes that has bearings. /6 A-body had a box with bushings.
70 parts book shows #2808420 assy. for B,E and A w/V-8. 2808419 for /6 A-body.
I can't find anything about shimming the box in the FSM and using all my fingers and toes can't begin to count how many boxes I've pulled and have never seen any shims. I think the problem is with the pitman arm.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E-body front suspension question [Re: moparmarks] #1530992
11/16/13 11:36 AM
11/16/13 11:36 AM
I've used the same 16:1 manual box on A and E circle track cars so the interchange is the same. What I was referring to in an earlier post is I think an earlier K member either locates the eng different fore/aft and or tilts the steering box different. I doubt if that is the case in your deal but since yours was a basket case I wanted to throw that possibility out there but k.i.s.s. as said I think it's a pitman/idler issue. I've never seen shims there either & if you added em it'd mess up the column/coupler alignment I'd think.
Re: E-body front suspension question [Re: RapidRobert] #1530993
11/16/13 11:40 AM
11/16/13 11:40 AM
moparmarks Offline
moparmarks  Offline
Robert the difference in the box angle on the K-frame was the 70B only frame that is a cross between the 68-9B frame and the 70-4E/71-2B that have different angles. I guess if he has a 68-9B or 70B frame and an E arm could be a problem.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: E-body front suspension question [Re: moparmarks] #1530994
11/16/13 11:45 AM
11/16/13 11:45 AM
moparmarks Offline
moparmarks  Offline
Looking at his pics again I see that he has the correct sway bar.
OP you might check and make sure you don't have a 70B K-frame. That would have the different box angle.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: E-body front suspension question [Re: moparmarks] #1530995
11/16/13 11:45 AM
11/16/13 11:45 AM
Thank you Mark as we have a circle track E body with a bent K (hit the wall) & I'll now know what is what when I get around to getting on it
Re: E-body front suspension question [Re: RapidRobert] #1530996
11/16/13 03:28 PM
11/16/13 03:28 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Is there any way to tell if the K member is correct? the coin on the front is stamped with the number 72. It's the only number i can find. Everything else bolts up nice. If the steering box or pitman arm were a 1/2 inch lower it would work. But I would like to know it's correct I don't wan't to rig this.I will try some othe box's this weekend and see what happens.
Re: E-body front suspension question [Re: 340swing] #1530997
11/16/13 03:34 PM
11/16/13 03:34 PM
moparmarks Offline
moparmarks  Offline
GG's book doesn't show a 72. Could it be a 12 which is early E body?
70B is a 90 wo/ skid and 79 w/ skid.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: E-body front suspension question [Re: moparmarks] #1530998
11/16/13 03:46 PM
11/16/13 03:46 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I'm confused there are different part numbers or casting numbers (see dacloana's post) but moparmarks post says all BE and A V8 share the same box. I searched for 2537346 and 2537350-6 comes up ebody my number came up for an A-body. Biginchmotor has several other boxes with different numbers that I will try to match up. But I'm not sure what should be on the car.
Re: E-body front suspension question [Re: 340swing] #1530999
11/16/13 03:48 PM
11/16/13 03:48 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I will look at the coin when I get home I guess it could be a 12 I thought it was 72 but I will look again.
Re: E-body front suspension question [Re: 340swing] #1531000
11/16/13 04:19 PM
11/16/13 04:19 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Coin on my 70 challenger is "72". 5/70 LA built deputy 318/3spd, 3rd owner, car had virtually all it's correct fasteners, etc, found on an unmolested car. Why would anyone mess with a 318/2bbl car anyway? Shims in pic (posted on another thread) were in it when I took it apart.
jess
Yeah, it's hopped up to over 160...
Re: E-body front suspension question [Re: jt4406] #1531001
11/16/13 04:49 PM
11/16/13 04:49 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Nice picture, Funny thing this car is also a 3spd but a 340 convertible.I wonder if that means anything. I'm about a 1/2 inch off so shims are not going to help.
Re: E-body front suspension question [Re: 340swing] #1531002
11/16/13 09:03 PM
11/16/13 09:03 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
The coin is a 72, and it was pointed out to me that the number is also on the broadcast sheet line 4 under frame and sure enough it is. You learn something new every day. So i'm back to the steering box. Does anybody have a known E-body manual steering box with casting number 2537350-6. If it's in the car you cant see the number it's between the housing and the K-frame. I need the measurement from the end of the case to the end of the shaft mine is 2 5/16th.
Re: E-body front suspension question [Re: 340swing] #1531003
11/16/13 09:53 PM
11/16/13 09:53 PM
moparmarks Offline
moparmarks  Offline
Good info Jess.
Those are the numbers in my 70/1 FPM.
I have a few boxes down at the yard. I'll check the numbers.
I've always though it was common Mopar knowledge that A,B and E have the same bearing boxes and /6 A-body had the bushing box which is what my books show? I've interchanged them several times over the years.
Flaming River, Firm Feel, etc. show the same for A,B and E.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: E-body front suspension question [Re: moparmarks] #1531004
11/16/13 10:01 PM
11/16/13 10:01 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I think the box is the same but they may use a different length shaft. for A B and E. I'm guessing here but either way the one I have has the wrong casting number. Let me know if you have one. Thanks
Re: E-body front suspension question [Re: 340swing] #1531005
11/16/13 10:12 PM
11/16/13 10:12 PM
The shaft length is the same
Re: E-body front suspension question [Re: RapidRobert] #1531006
11/16/13 10:32 PM
11/16/13 10:32 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Brian, just out of curiosity, why not loosen the bottom bolt on the box, and back the two top bolts off, tilting the box down, until the inner tie rods are the same distance from the torsion bars, and see how much gap you have between the steering box and the frame. Won't cost anything to do, and maybe a small gap there will move the outer end of the pitman arm down more than you think it would, due to it's arc of travel....?? Just grasping at straws here.
jess
Re: E-body front suspension question [Re: jt4406] #1531007
11/16/13 10:45 PM
11/16/13 10:45 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I will give it a try. But i'm stuck on the casting number, it is not the one others have posted for a Ebody. Making me think the box is wrong for the car. I will put it back on and take some pictures for the thread.
Re: E-body front suspension question [Re: jt4406] #1531008
11/17/13 12:13 PM
11/17/13 12:13 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
jt4406 it took 1/4 inch bolts as mock up shims to make it clear the torsion bar. That isn't as bad as I thought but does this seem like an option to anybody? I could get some shims or make them but i have never seen a box shimmed. I know some have posted that they have seen this but the pics are hard to tell how big of a shim. I personaly don't like it but everything I have for the car so far checks out. Could this be the right box and it was shimmed?
Re: E-body front suspension question [Re: 340swing] #1531009
11/17/13 12:17 PM
11/17/13 12:17 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
2
Page 3 of 4 1 2 3 4
