Re: 1970 318 E body What rear axle should it have? [Re: Finoke] #1530774
11/11/13 02:35 AM
11/11/13 02:35 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i made a simple "tool" to get the plug out. i cant remember what size nut/bolt i used but it was maybe a 3" bolt with 2 nuts on the end of it tightened together so they would not move. i ground 2 of the opposing points off the nut on the end, it fit right into the the plug. you just need to find a nut that almost fits in the plug and you will know what size it is.
Re: 1970 318 E body What rear axle should it have? [Re: 65rbdodge] #1530775
11/11/13 02:50 AM
11/11/13 02:50 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
thats a good idea, thank you
