kevin,
I just didnt want to call up...the web site said do not call with ?s,as they took a lot of time and work to put all the info on the listing
I went roller and got a voodoo 60710 and lunatis matching spring
didnt realize they where double with a damper and need seals and machine work,had to buy another set that drop on with out removing the heads...comp 901s
hughes suggest there springs only also,dont want doubles and machine work,want to do it with heads on the engine
and get it right this time whith out the 130$ door stops
is all this gonna work with the stock HD rockers,pushrods,roller lifters, single springs(hughes) stock seals,and spring retainers
thanks for the help...if you rather I call I can do that too...just dont want to waste you time with my dumb ?s
I am no racing guru,just a shadetree rabid parts changer that wants some sound in a 318
what discount?......
