who knows hughes engines cams? #152951
11/18/08 06:25 PM
11/18/08 06:25 PM
scratchnfotraction Offline OP
looking for some info on the whiplash cams
how much differance over the 60710 voodoo roller cam I have now?
Re: who knows hughes engines cams? [Re: scratchnfotraction] #152952
11/18/08 08:22 PM
11/18/08 08:22 PM
Columbus Ga
reflections7 Offline
Columbus Ga
you might get some different answers but I have loved hughes stuff and will get a cam from them when I build my street roller 360.
Re: who knows hughes engines cams? [Re: scratchnfotraction] #152953
11/19/08 02:59 AM
11/19/08 02:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have used the regular Hughes cams, but not the whiplash cams. I did notice the whiplash cams have narrower lobe seperation which will give the cam more overlap (rougher idle) at the same duration compared to a wider LSA cam.
Re: who knows hughes engines cams? [Re: 451Mopar] #152954
11/19/08 03:13 AM
11/19/08 03:13 AM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
I can't comment on the whiplash cams but I had one of their solid cams in my 11:1 451 w/unported Eddy RPM's. It pushed my 3700-3800# Charger to 11.30-11.40 at the track. My bro also had one in his pump gas 440 w/Indy's that ran mid-10's in a 71 Dart. Good reviews from me.
Re: who knows hughes engines cams? [Re: Charger453] #152955
11/19/08 09:50 AM
11/19/08 09:50 AM
I looked at the marketing/sales pitch and sounds just like what I want
idles like a funny car,smooths out about 2000rpms and the sweet spot is 2000-5000 rpm
works with low compression 8.1-8.7 318 for us guy that run the lo-po units
I just want to know does it come in a roller cam?
or how to get that in a roller cam and be on par with it performance wise
a poser cam if you will
the voodoo 60710 roller I have now is sweet and has the level of performance I am happy with but would love to have that and the funny car idle at a stop light
the thumper needs lots of comp,stall,gears so it out...
and I have gone roller and dont want to go back to slider cams now
so a roller swap is the ticket for me
any one else? thanks
Re: who knows hughes engines cams? [Re: scratchnfotraction] #152956
11/19/08 10:38 AM
11/19/08 10:38 AM
funny car idle may sound cool but it sucks when youre sitting at a stop light trying to keep the motor from dying/surging/choking out. but I doubt that cam is all that radical to be doing that.
what are the specs on it?
Re: who knows hughes engines cams? #152957
11/19/08 10:58 AM
11/19/08 10:58 AM
said they have it work out and it runs better than the sound would imply
its under there 318 muscle car cam
485/518
213/226@.050
109lsa
sweet spot 2000-5300
designed raise not low cyl pressure (torque killer)
posed to work for a real low comp teen but be a good daily driver on the street
I am slow any ways..might as well have the sound too
Re: who knows hughes engines cams? [Re: scratchnfotraction] #152958
11/24/08 10:52 AM
11/24/08 10:52 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
scratchnfotraction,
The Whiplash cams have been very popular and we are getting a lot of good feedback on them. If you are interested we can provide the same thing in a hydraulic roller. We are just not advertising them yet. If you get a chance give us a call and we can get one going for you.
Kevin
Re: who knows hughes engines cams? [Re: Hughes] #152959
11/24/08 05:11 PM
11/24/08 05:11 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Thanks Hughes, for all the memories. The 440 heads you did, and matched deep ported intake, are awesome. the big block turned out to be wilder than my wildest dreams. I love the "Big" valve lift which was scaring me away at first. You did it right, and provided more than fair customer service. Great job!
Re: who knows hughes engines cams? [Re: mark7171] #152960
11/25/08 04:04 PM
11/25/08 04:04 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
mark7171,
WOW! Thanks for the nice comments. I will pass them along to the guys in the shop as well.
Kevin
Re: who knows hughes engines cams? [Re: Hughes] #152961
11/25/08 05:07 PM
11/25/08 05:07 PM
cool,I want one in a roller cam please
do you have a single spring with damper that will drop on with stock seals and retainers?
thanks
Re: who knows hughes engines cams? [Re: scratchnfotraction] #152962
11/25/08 06:21 PM
11/25/08 06:21 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
scratchnfotraction,
Call us up and be sure to ask for the discount.
Kevin
Re: who knows hughes engines cams? [Re: Hughes] #152963
11/26/08 09:34 AM
11/26/08 09:34 AM
kevin,
I just didnt want to call up...the web site said do not call with ?s,as they took a lot of time and work to put all the info on the listing
I went roller and got a voodoo 60710 and lunatis matching spring
didnt realize they where double with a damper and need seals and machine work,had to buy another set that drop on with out removing the heads...comp 901s
hughes suggest there springs only also,dont want doubles and machine work,want to do it with heads on the engine
and get it right this time whith out the 130$ door stops
is all this gonna work with the stock HD rockers,pushrods,roller lifters, single springs(hughes) stock seals,and spring retainers
thanks for the help...if you rather I call I can do that too...just dont want to waste you time with my dumb ?s
I am no racing guru,just a shadetree rabid parts changer that wants some sound in a 318
what discount?......
