N E 1 using a 4 hole spacer on an M-1 #1528918
11/05/13 01:01 PM
11/05/13 01:01 PM
Sterling Hts, MI
2
2FASTCORONET Offline OP
Sterling Hts, MI
Thinking about adding a 4 hole spacer to pick up some torque on a M-1 manifold that has a 1" open spacer. If so, did it help? What type? I've got room since I run a scoop. Thanks Dennis
Re: N E 1 using a 4 hole spacer on an M-1 [Re: 2FASTCORONET] #1528919
11/05/13 02:34 PM
11/05/13 02:34 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Care to share any info on your combo?
Re: N E 1 using a 4 hole spacer on an M-1 [Re: 2FASTCORONET] #1528920
11/05/13 06:53 PM
11/05/13 06:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Spacers are always one of those "it depends" type of changes. They're usually cheap enough that they don't bust the budget to buy 'em and try 'em.
Keep in mind that if you have a carb w/ a 1-3/4" baseplate (850, 950, 1000), you need to be sure the 4-hole spacer is machined for the larger butterfly size. I've found a number of them that are suitable only for the smaller 1-11/16" size (650, 750), so you need to check to see if they even specify what size bore it has.
