Correct casting number 1970 drum brake master cyl. #1525120
10/29/13 10:21 AM
10/29/13 10:21 AM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
What is the correct casting number for a 1970 A, B, and E body drum brake master cylinder?
Re: Correct casting number 1970 drum brake master cyl. [Re: JRepucci] #1525121
10/30/13 12:08 PM
10/30/13 12:08 PM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
2660809 is the casting number. The last year for the bolt-on,
double hump lid. Used from 67-70 drum brake, all models.
67 cars may of had 2225601 castings, same cylinder. Repops
are available, but without the number, has Bendix cast on bottom.
Re: Correct casting number 1970 drum brake master cyl. [Re: demonH1B] #1525122
10/30/13 01:52 PM
10/30/13 01:52 PM
USA
b54406barrel Offline
USA
Think this is the original of my 70 rr.
Re: Correct casting number 1970 drum brake master cyl. [Re: b54406barrel] #1525123
10/30/13 02:45 PM
10/30/13 02:45 PM
JRepucci Offline OP
JRepucci  Offline OP
Excellent. Thanks guys.
This is the one that I have.
Re: Correct casting number 1970 drum brake master cyl. [Re: JRepucci] #1525124
10/30/13 06:50 PM
10/30/13 06:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Correct casting number 1970 drum brake master cyl. [Re: DAYCLONA] #1525125
10/31/13 12:02 AM
10/31/13 12:02 AM
JRepucci Offline OP
JRepucci  Offline OP
Here is another master that I have... no casting number.
Re: Correct casting number 1970 drum brake master cyl. [Re: JRepucci] #1525126
10/31/13 12:12 AM
10/31/13 12:12 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Isn't the casting number on the base????
Admiration For Multiple Carburetor Vehicles...
Re: Correct casting number 1970 drum brake master cyl. [Re: Stewpar] #1525127
10/31/13 12:27 AM
10/31/13 12:27 AM
JRepucci Offline OP
JRepucci  Offline OP
On the table that Dayclona posted; the 3420961 has no casting number... yes, it could be a replacement.
Re: Correct casting number 1970 drum brake master cyl. [Re: JRepucci] #1525128
10/31/13 10:03 AM
10/31/13 10:03 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
On the picture you posted, what is the number stamped into the base then? Sure looks like 2660809????
Re: Correct casting number 1970 drum brake master cyl. [Re: Stewpar] #1525129
10/31/13 10:12 AM
10/31/13 10:12 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Took a few seconds to see what you're talking about but it's on the mounting flange of the casting...
Re: Correct casting number 1970 drum brake master cyl. [Re: screamindriver] #1525130
10/31/13 10:25 AM
10/31/13 10:25 AM
JRepucci Offline OP
JRepucci  Offline OP
WOW! I didn't notice the casting number on the flange. But then in the picture; there it is. Thanks
Re: Correct casting number 1970 drum brake master cyl. [Re: JRepucci] #1525131
10/31/13 06:12 PM
10/31/13 06:12 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Great, I thought I was losing my mind there for just a second!
