Re: Cracked Block! [Re: Eric] #1525088
10/29/13 10:23 PM
10/29/13 10:23 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I've heard the 66' blocks are among the worst. I had one in the Duster and it broke also...with much less HP...If you want I have a 76 440 short block you can have...going to need some cleaning up..
Thanks Eric but I am ok on blocks here. Just not sure which way to go right now with the budget at hand. Thanks for the offer though. Beep
Re: Cracked Block! [Re: Bigbeep] #1525089
10/29/13 10:30 PM
10/29/13 10:30 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
go with the 400 block. i have cracked a 73 440. up threw the mains and a crack between the freezrplugs all on the drivers side.
i got a thick 440 late block. we shall see how this lasts but i
will build a 400 next no more 440 that are stepped on sort of hard.
good luck.
Re: Cracked Block! [Re: roadhazard] #1525090
10/29/13 10:33 PM
10/29/13 10:33 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Sorry to see that John
How do you manage to keep the side of that block so clean?
Aren't they all that clean? Vacuum pump makes keeping the slippery stuff on the inside easy! doesn't seem to be working for the coolant though.............. Oh and some really, really good gaskets buddy! Beep
Re: Cracked Block! [Re: Wv68charger] #1525091
10/29/13 10:37 PM
10/29/13 10:37 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
John I hate to see a post like this but I can tell you if and when you build another one it's worth the wait to buy an Indy block just be sure to have it checked out and go big if your budget can afford it you will be much better off.
Yeah an Indy block is at the top of my wish list. But reality I'm sure, will keep me grounded. Beep
Re: Cracked Block! [Re: Bigbeep] #1525092
10/29/13 10:58 PM
10/29/13 10:58 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Dam, sorry to hear about this John. Like many of the folks that are 10 times smarter and more experienced then me, I would go with the 400 block as well. Good luck man, can't wait to see one of my favorite Mopars back up and running!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Cracked Block! [Re: Bigbeep] #1525093
10/29/13 11:00 PM
10/29/13 11:00 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
How much steam can you make with one safely? Thanks, Beep
John my 400/493 makes around 750 HP. Flat tappet cam, 12.7 comp., nothing very fancy.
Don
Re: Cracked Block! [Re: Bigbeep] #1525094
10/29/13 11:22 PM
10/29/13 11:22 PM
AndyF Offline
AndyF  Offline
I've never seen a vertical crack in that location but the horizontal crack between the freeze plugs is very common. That vertical crack is interesting. There shouldn't be much stress in that area. Hard to say without looking at the parts during a tear down. Rotating assembly could be out of balance, maybe detonation, maybe something bad going on with the hard block.
Re: Cracked Block! [Re: Bigbeep] #1525095
10/30/13 02:59 PM
10/30/13 02:59 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
[quote I have also been told that the 66 and 67 blocks were the thinnest in the area at the bottom of the water jackets. Beep
I hope that's not true I got a line on a 66 or 67 block
Sorry about the miss fortune
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Cracked Block! [Re: 67mprfan] #1525096
10/30/13 03:49 PM
10/30/13 03:49 PM
dogdays Offline
dogdays  Offline
I think AndyF had a great thought - it could be the hard-block.
R.
Re: Cracked Block! [Re: dogdays] #1525097
10/31/13 01:08 AM
10/31/13 01:08 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I am pretty sure it is a result of the fill. If you look at the vertical crack location, it starts about a 1/2" below the top of the fill. And the cracks along the side are at the bottom of the water jacket around the cylinders. No more bandaids on this one. Beep
Re: Cracked Block! [Re: Bigbeep] #1525098
10/31/13 01:31 AM
10/31/13 01:31 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No doubt IMO its a result of a Fill gone bad problem . Its probably and most likely effecting the roundness of the cylinders as well.
The outside cracks can be easily welded with todays tech. But I wouldnt trust whats happening with the inside cylinders contorsions. Scrap it, IMO
Re: Cracked Block! [Re: Sport440] #1525099
10/31/13 10:07 AM
10/31/13 10:07 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Kinda funny how guys use concrete to prevent problem and then it causes other issues. 35+ years of running stock blocks and NEVER filled one yet. Concrete's for sidewalks, driveways, and in-ground swimming pools.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cracked Block! [Re: pittsburghracer] #1525100
10/31/13 01:57 PM
10/31/13 01:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Unless the inside of the block is perfectly clean the hardblock will not adhere to the casting and water will migrate between the wall and filler.We have seen poured blocks that cracked similar because the fill closed of water circulation and caused overheating and with expansion cracked the block,no freezing involved.
Re: Cracked Block! [Re: B G Racing] #1525101
10/31/13 08:24 PM
10/31/13 08:24 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
I have never been a fan of filling the block with any thing except coolant. There are hormonics inside that have to be asorbed. Oil and coolant do more than their share of absorbing the these bad boys. Filling the block with a hard surface just intensifies these hormonics. Like Bob said if it is loose it will act like a hammer inside.
