Cracked Block! #1525068
10/29/13 01:17 AM
10/29/13 01:17 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Anyone ever see one crack in this area? Beep
Re: Cracked Block! [Re: Bigbeep] #1525069
10/29/13 01:25 AM
10/29/13 01:25 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
A little info on this block. 66 casting for a 67 model year. filled to the bottom of the water pump holes. Had pinned a crack last spring on the other side between freeze plugs and now it has cracked between the other freeze plugs on the drivers side and found this one this evening while laying under the car. No more money into this block. Doing some soul searching on which way to go. This will be the second block I kick off the tailgate at the scrap yard. Machine work alone in these 2 blocks would have got me half way to a indy block. So how much horsepower can one make with a low deck block? Is it 700ish like a RB? Beep
Re: Cracked Block! [Re: Bigbeep] #1525070
10/29/13 01:41 AM
10/29/13 01:41 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i'm guessing this it mounted with a motor plate so the crack near the mount can't be from stress.
is this engine left with water in it in freezing weather? just because it's filled doesn't mean water can't get around the fill and cause problems especially if the fill wasn't done carefully. those cracks look like they're from ice not HP.
even though i carefully filled mine and drilled drain holes at the level of the fill i still put antifreeze in it during the winter and circulate it for a while.
i just don't see those cracks coming from HP unless something weird is going on.
Re: Cracked Block! [Re: jamesc] #1525071
10/29/13 02:00 AM
10/29/13 02:00 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Nope! Never sits with plain water in it. Was sonic checked and magged before machining was done also.
Original crack happened in august at the 10k race 2 years ago. Thought it may have been a freeze plug seeping and would just relieve pressure after each pass. Later found that it was cracked next to the freeze plug. Was told that it was because it didn't have a mid plate and just a front motor plate wasn't enough. So I installed a mid plate which was no easy task. I ran it with sodium silicate last year the few times I had it out. By the mopar race at Norwalk it was leaking again so I parked it. This past spring I pulled it out and stich pinned it between the freeze plugs and it was good...... for a while. Now it is cracking between the front 2 freeze plugs and I found this vertical crack this evening as I was laying under it in disgust. I have also been told that the 66 and 67 blocks were the thinnest in the area at the bottom of the water jackets. I just wonder if it is too rigid with the fill in it and something has to give and it is the casting! Beep
Re: Cracked Block! [Re: Bigbeep] #1525072
10/29/13 02:21 AM
10/29/13 02:21 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
IMO find a nice early 400 block
Re: Cracked Block! [Re: Bigbeep] #1525073
10/29/13 02:56 AM
10/29/13 02:56 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've ran several different 440 wedges, 426 Hemi and 400 with Elephant ears on the front with no midplate and a stock type trans. mount,they never cracked anywhere I've never had, seen or heard of a stock block crack like yours that wasn't frozen first
Re: Cracked Block! [Re: Cab_Burge] #1525074
10/29/13 03:15 AM
10/29/13 03:15 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I thought the same thing,that vertical crack in particular. I have only seen vertical cracks from frost.
I suppose the filler has absorbed water and/or is porus enough the expand on its own when frozen
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Cracked Block! [Re: 6bblFLASH] #1525075
10/29/13 03:48 AM
10/29/13 03:48 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Possible the filler wasn't tamped during the pour, and had air voids?
Re: Cracked Block! [Re: 451Cuda] #1525076
10/29/13 03:57 AM
10/29/13 03:57 AM
NC
1967Valiant Offline
1967Valiant  Offline
NC
A lot of people might not agree with me. When you fill a block I think you should put torque load on block. Ie heads mains pan rails bell housing. Then pour the block and let it set a month before any machine work. Just my opinion.
If I was in your position I would call Todd at Comp wedge engines
Re: Cracked Block! [Re: 1967Valiant] #1525077
10/29/13 05:31 AM
10/29/13 05:31 AM
Arizona
Chris'sBarracuda Offline
Arizona
I'm thinking it's a 47 year old block that has a history that you don't know a thing about.
Then you pound on them with 600+ hp..
Just thinking out loud here.. Old Old blocks..
But, yes a 70's 400 block would be much better..
I've seen them take a beating and keep on ticking..
Chris..
Re: Cracked Block! [Re: Chris'sBarracuda] #1525078
10/29/13 06:37 AM
10/29/13 06:37 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have seen a small block crack right there, and it was from a front impact with a ditch. Maybe this block was in a car that had been in a collision in the past, altough I would think a sonic check would have caught it.
Re: Cracked Block! [Re: viperblue72] #1525079
10/29/13 07:22 AM
10/29/13 07:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've seen the them,frozen,w/o block filler. Now I can say when we knocked the inside water jacket out of a Hemi from a broken rod. I covered it with bondo, filled with hardblock and Moroso Ceramic seal. Ran it for 2 years. 2nd Hemi block numerous cracks in the side, and Moroso Ceramic seal, never leaked. 440 block cracked between the freeze plugs, Moroso Ceramic seal, never leaked. Just my experience.
Doug
Re: Cracked Block! [Re: Bigbeep] #1525080
10/29/13 10:55 AM
10/29/13 10:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those look like freeze cracks to me.
Re: Cracked Block! [Re: jamesc] #1525081
10/29/13 11:32 AM
10/29/13 11:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've seen that crack down the frost plug lines before. It's more common than one would think stating with older b and RB engines. One of the reasons they put a stiffening rib down the sides of the blocks in late 1968 and 1969 and up models.
Re: Cracked Block! [Re: Dodgem] #1525082
10/29/13 07:43 PM
10/29/13 07:43 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
If it matters the fill in this block is a 2 part epoxy that actually has iron in it. If my memory serves me, my machinist did have it cure for a week before doing any work to it.
It may be the case that it was froze at some point in its lifespan. I would have thought that it would have shown up when magged.
On the 400 block suggestion. How much steam can you make with one safely? Thanks, Beep
Re: Cracked Block! [Re: 6bblFLASH] #1525083
10/29/13 08:05 PM
10/29/13 08:05 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
It hasn't froze since I assembled it in 2011. Beep
Re: Cracked Block! [Re: Bigbeep] #1525084
10/29/13 08:14 PM
10/29/13 08:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That is an easy fix with today's nickle rod.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cracked Block! [Re: Bigbeep] #1525085
10/29/13 08:16 PM
10/29/13 08:16 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sorry to see that John
How do you manage to keep the side of that block so clean?
Re: Cracked Block! [Re: Bigbeep] #1525086
10/29/13 08:17 PM
10/29/13 08:17 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I've heard the 66' blocks are among the worst. I had one in the Duster and it broke also...with much less HP...If you want I have a 76 440 short block you can have...going to need some cleaning up..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Cracked Block! [Re: Bigbeep] #1525087
10/29/13 09:54 PM
10/29/13 09:54 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
John I hate to see a post like this but I can tell you if and when you build another one it's worth the wait to buy an Indy block just be sure to have it checked out and go big if your budget can afford it you will be much better off.
