Re: Cracked Block!
[Re: Eric]
#1525088
10/29/13 10:23 PM
10/29/13 10:23 PM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
I've heard the 66' blocks are among the worst. I had one in the Duster and it broke also...with much less HP...If you want I have a 76 440 short block you can have...going to need some cleaning up..
Thanks Eric but I am ok on blocks here. Just not sure which way to go right now with the budget at hand. Thanks for the offer though. Beep
Re: Cracked Block!
[Re: roadhazard]
#1525090
10/29/13 10:33 PM
10/29/13 10:33 PM
Bigbeep
Central Ohio, USA
Sorry to see that John
How do you manage to keep the side of that block so clean?
Aren't they all that clean? Vacuum pump makes keeping the slippery stuff on the inside easy! doesn't seem to be working for the coolant though.............. Oh and some really, really good gaskets buddy! Beep
Re: Cracked Block!
[Re: Wv68charger]
#1525091
10/29/13 10:37 PM
10/29/13 10:37 PM
Bigbeep
Central Ohio, USA
John I hate to see a post like this but I can tell you if and when you build another one it's worth the wait to buy an Indy block just be sure to have it checked out and go big if your budget can afford it you will be much better off.
Yeah an Indy block is at the top of my wish list. But reality I'm sure, will keep me grounded. Beep
Re: Cracked Block!
[Re: Bigbeep]
#1525093
10/29/13 11:00 PM
10/29/13 11:00 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
How much steam can you make with one safely? Thanks, Beep
John my 400/493 makes around 750 HP. Flat tappet cam, 12.7 comp., nothing very fancy. Don
Re: Cracked Block!
[Re: Bigbeep]
#1525095
10/30/13 02:59 PM
10/30/13 02:59 PM
Posts: 1,030 ohio
67mprfan
ohio
[quote I have also been told that the 66 and 67 blocks were the thinnest in the area at the bottom of the water jackets. Beep
I hope that's not true I got a line on a 66 or 67 block
Sorry about the miss fortune
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Cracked Block!
[Re: Bigbeep]
#1525098
10/31/13 01:31 AM
10/31/13 01:31 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I am pretty sure it is a result of the fill. If you look at the vertical crack location, it starts about a 1/2" below the top of the fill. And the cracks along the side are at the bottom of the water jacket around the cylinders. No more bandaids on this one. Beep
No doubt IMO its a result of a Fill gone bad problem . Its probably and most likely effecting the roundness of the cylinders as well.
The outside cracks can be easily welded with todays tech. But I wouldnt trust whats happening with the inside cylinders contorsions. Scrap it, IMO
