Disc brake part number question- '77 Diplomat #1524851
10/28/13 09:30 PM
10/28/13 09:30 PM
OK
David_Trimble Offline OP
OK
Hi-
I don't have access to a parts manual for a '77 Dodge Diplomat- could someone tell me what the part number is for the round gasket for the disc brake backing plate? It goes between the backing plate and the spindle itself. I'm getting ready to do a disk brake conversion on my '69 Charger and I was cleaning up a set of junk yard spindles that I got to use when I found that the gaskets are pretty shot...
Thanks!
David
'69 Dodge Charger R/T
Re: Disc brake part number question- '77 Diplomat [Re: David_Trimble] #1524852
10/28/13 10:27 PM
10/28/13 10:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I think that you mean "splash shields", right? Disc brakes had no backing plates.
I never use those anyway. They retain heat and will make a terrible screeching noise if a rock gets between them and the rotor. Rick Ehrenberg suggests to toss them. Since your car isn't an attempt at a correct restoration, why keep them?
Re: Disc brake part number question- '77 Diplomat [Re: David_Trimble] #1524853
10/28/13 11:26 PM
10/28/13 11:26 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Use the splash shields.
You can make your own gasket from thin sheet closed cell foam.
If not, I think RestoRick has the gaskets. DMT may have them too, but they dont show on his website.
Re: Disc brake part number question- '77 Diplomat [Re: Kern Dog] #1524854
10/29/13 10:33 PM
10/29/13 10:33 PM
OK
OK
Right, I had meant splash shields.
Yea I was thinking of just getting that thin foam material from the local part store and just cut them out. I managed to salvage one of them in good enough shape that I can use it as a template if I just 'fill in the blanks'.
But if I can't find the foam sheeting then I'll check out the websites and see if I can't get them that way.
Thanks!
David
Re: Disc brake part number question- '77 Diplomat [Re: David_Trimble] #1524855
10/30/13 10:44 PM
10/30/13 10:44 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
If you want to look for an original....
Looks like you need #14, P/N 2944704.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Disc brake part number question- '77 Diplomat [Re: David_Trimble] #1524856
10/30/13 10:49 PM
10/30/13 10:49 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I would imagine if Jim (71TA) does not make them already, he might be able to use the one you have as a template to run them off...might be worth checking with him.
Re: Disc brake part number question- '77 Diplomat [Re: OzHemi] #1524857
10/31/13 02:00 AM
10/31/13 02:00 AM
...or introduce a pool noodle to a meat slicer
