Re: 505 dry sump headed to the dyno
[Re: 70blackfish]
#152534
07/14/09 08:21 PM
07/14/09 08:21 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
This is a great post keep up the nice work
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: AndyF]
#152535
07/14/09 08:29 PM
07/14/09 08:29 PM
Posts: 16,925 NC
440Jim
NC
It has a lot of 800 hp pulls on it and the bottom end is all stock except for some ARP main studs.
As you have shown, a stock block at that power level needs some help such as aluminum rods, aluminum main caps, girdle, something to reduce the chance of cracking cast iron.
[Re: 440Jim]
#152536
07/14/09 09:50 PM
07/14/09 09:50 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[Re: AndyF]
#152541
07/15/09 09:17 AM
07/15/09 09:17 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what did the old block have for caps? did it have a girdle? this makes me nervous, i've been think about spraying mine
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#152542
07/15/09 10:51 AM
07/15/09 10:51 AM
Posts: 996 Queens, New York
Harley
Queens, New York
Thanks for the information Andy. I know a few people that have better heads then the Indy EZ heads on stock blocks. I am going to point out this post to them and hopefully enlighten them on the possibility that they are driving time bombs.
[Re: Harley]
#152545
07/15/09 09:22 PM
07/15/09 09:22 PM
Posts: 31,033 Oregon
AndyF
Yep, I agree. Anything cylinder head that is capable of making more power than the EZ head really deserves an aftermarket block.
I'm going to be interested to see if there is any power difference between what my cracked 505 was making and what the new 514 will make. The 514 will have the same exact heads, cam, intake, carb, etc that I was running on the 505 so the main difference will be the block itself and small changes to the bore and stroke.
[Re: sixpackgut]
#152547
07/18/09 08:24 AM
07/18/09 08:24 AM
Posts: 977 Colorado
506RR
Colorado
Makes me nervous as well. I am spraying a 150 HP shot on mine, and it is making right at 800 HP plus it is in a 4050 lbs car. Ran a 10.59 @ 127 last time out, and that equates to right at 675 HP to the wheels, which assuming drive train loss is about 800 at the crank.
Mine does have a Hughes Girdle, so hopefully this is helping me out some. Wish I would have went with the BCR Products Girdle that includes aluminum caps!
