Re: 505 dry sump headed to the dyno
[Re: 5spdcuda]
#152473
11/18/08 10:26 PM
11/18/08 10:26 PM
Posts: 31,034 Oregon
AndyF
It is a dyno pan so no reason to run a shallow pan when there is room to run a deep one. Usually oil pans work better the bigger they are. Something about the extra volume providing more space for the pumping energy to spread out in I suppose. I don't have test data myself on that theory but plenty of other guys seem to agree that bigger is better when it comes to oil pans. The theory makes sense to me so I just had Charlie build the biggest pan that would fit.
[Re: Bubba]
#152475
11/18/08 10:55 PM
11/18/08 10:55 PM
Posts: 614 Michigan
Get-X
Thanks for the info. I was wondering if we could get a price comparison between wet and dry sumps? Including the cost to mount and plumb them and the accum. tank?
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: bigtimeauto]
#152476
11/19/08 02:36 AM
11/19/08 02:36 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
moroso makes those gaskets. 93055 is the number. They will last forever unless you do something to them. They work best on machined surfaces and cast valve covers.
One more thing is i only use the center 4 bolts.
yep....they do leak real good with $25 stamped valve covers..... dont ask how i know.
[Re: AndyF]
#152477
11/19/08 01:51 PM
11/19/08 01:51 PM
Posts: 5,618 long island NY
Ari440
long island NY
ANDY
any pics and part numbers of the crank trigger
1.39 9.85 - 137 mph
[Re: AndyF]
#152480
12/05/08 10:14 PM
12/05/08 10:14 PM
AndyF
We ran both the Super Victor and the Mopar 337 intake. Also ran 1.70 and 1.85 ratio rocker arms on the intakes. Best power was 1.85 intakes with the 337 intake.
I assumed the 337 intake would be down 15 or 20 hp from the Super Victor but actually the 337 intake made the most power. Not sure why that is the case but it did.
Peak power with the 337 intake was 797 hp. The best pull with the Super Victor was 791 hp. Both of those numbers were with the 1.850 rocker arms. Best pull with the 1.70 intake rocker arms was 780 hp so the bigger ratio was worth about 10 hp.
Carb was rich with the 337 intake so there is probably another 10 hp to be found. We had the carb dialed in with the Super Victor but the 337 intake must be working better since it makes more power with less jet. I'm still having a tough time believing the 337 intake works better than the Super Victor but if you can't trust back to back dyno pulls then what are you going to trust?
[Re: AndyF]
#152481
12/05/08 10:19 PM
12/05/08 10:19 PM
AndyF
The dry sump setup worked perfectly. Oil pressure was nice and solid in the 60 psi range.
This motor has a ton of pulls on it but the Oberg screen looks perfect everytime we take a peek. This motor isn't putting any trash at all into the oil so that is a good sign. It has a lot of 800 hp pulls on it and the bottom end is all stock except for some ARP main studs.
[Re: AndyF]
#152482
12/05/08 10:25 PM
12/05/08 10:25 PM
Posts: 5,160 Texas
dannysbee
Texas
Andy how did you like the new cam compared to what you have been using?
Getting old just means you were smarter than some and luckier than others.
[Re: ProSport]
#152487
12/06/08 02:20 AM
12/06/08 02:20 AM
AndyF
Andy, What was the cam lift with the 1.7 and 1.85 rockers?
Lobe lift on the cam is .393/.401 so with the 1.70 setup it was .649/.661 net lift.
With the 1.85/1.70 split ratio rocker arms the net lift was .706/.661.
This really isn't a very wild cam even with the 1.85 rocker arms. .706 lift isn't anything exotic these days. I was running some fairly mild Comp 26097 valve springs and the motor seemed happy up past 7300 rpm.
We saw the best peak power numbers at 7300 rpm with the 337 intake. Evidently the shorter runners on the 337 wants some more rpm to make power. The first pulls on the 337 intake we didn't turn it enough rpm and the power was down a bit. Then the dyno operator decided to lean on it a bit harder and the power jumped up a bunch.
[Re: AndyF]
#152489
12/06/08 02:26 AM
12/06/08 02:26 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Interesting, my CamMotion roller is 706/661 with 1.5's. Is there an advantage to running the smaller cam with bigger ratio rockers?
[Re: ZIPPY]
#152491
12/06/08 11:17 AM
12/06/08 11:17 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Andy , is there any way you can post the Graphs?
Peak is cool of course but the curve can be a lot more telling/useful. Thanks!
i had an M1 Stage VI standard port RB I bought from BradH that I wound up not using, Brad said Roger Helgessen worked the plenum roof transitions and it really came alive......the most power I've found working single planes has almost always been in the roof/plenum transition, not so much in the port walls themselves.
[Re: ZIPPY]
#152492
12/06/08 09:41 PM
12/06/08 09:41 PM
AndyF
I'm very surprised on the intake testing results, never would have guessed the 337 works that well.
We were surprised as well. Only thing I can think is that this engine combination liked the shorter runners in the 337 intake. I had to use a 4150 to 4500 adapter since I didn't want to change carbs. Usually the adapter kills a little power but it seemed to work okay in this case.
