Dimensions of 68 Dart longitudinal stripe
#1522474
10/23/13 11:55 PM
10/23/13 11:55 PM
Posts: 2,094 oberlin, Ohio
Rapid340
oberlin, Ohio
I am hoping someon will report the width of the main longitudinal stripe on a 68 GTS as well as the width of the smaller stripes (and the gap between stripes). My guess is the larger stripe is 1.25 inches and the smaller stripes may be .25 inch with a .25 inch gap seperating them from the wide stripe? Thanks
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Dimensions of 68 Dart longitudinal stripe
[Re: Rapid340]
#1522475
10/24/13 12:26 AM
10/24/13 12:26 AM
Posts: 43,828 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I had posted the info sometime in the last year or so, I will see if I can find it again. You do know that the stripe is not straight across the trunk, it comes to a point in the middle?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1522476
10/24/13 10:44 AM
10/24/13 10:44 AM
Rapid340
oberlin, Ohio
Rhino, I am referring to the stripe down the entire side on some 68 GTS darts, not a bumble bee stripe. It looks like a racing spripe with one wide stripe and two smaller pinstripes running parallel.
thanks
