Just a thanks to Brian Smith for getting it "all"
#1521649
10/22/13 08:57 PM
10/22/13 08:57 PM
Posts: 1,784 PA
W5DART66
PA
Hope it is ok Brian His kick a$$ dart went 5.35 at 129mph Saturday. This car is over 2800lbs has my smaller port w8s and what I would call fast bracket cam. Air was killer but that is still fast NA small block mopar (417Ci) Hope to get better intake on it yet Thanks for your hard work Brian
Re: Just a thanks to Brian Smith for getting it "all"
[Re: W5DART66]
#1521650
10/22/13 10:35 PM
10/22/13 10:35 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
That car is killer for sure. Wish mine was half as fast as that thing.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: sunroofgtx]
#1521653
10/23/13 01:23 AM
10/23/13 01:23 AM
Posts: 3,456 Out West
408strokerdart
Out West
Thanks Brett. It's been really good since put back together. People can't even believe how small this cam is and the intake has to be choking it. Really trying to decide what to do with it for next year. I have been thinking big, big wedge. But I guess I'm a small block guy and am intrigued by how quick I can make it and keep the small block. Might just have to do a new top end with the "big" port and a sheet metal intake and a cam to match. Maybe get the compression back up. Maybe go dry sump? If I do it, it will be a max effort this time. I still like the guys that shake their heads when walking away after looking my car over for the "bottle" and not finding one. I'm normally in the top 2 N/A door cars at any track I go to and that is at any weight. Still hoping for a pair of wins to finish out this year.
[Re: 408strokerdart]
#1521654
10/23/13 02:00 AM
10/23/13 02:00 AM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I know that guy .. not only is that car fast but, the build quality is unbelievable .. I parked my 64 next to his and was ashamed of mine And Brian and his wife are great people .. Brian is in my circle of trust
#1521655
10/23/13 02:06 AM
10/23/13 02:06 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Haulin the mail..Congrats!
[Re: bigdad]
#1521656
10/23/13 10:05 AM
10/23/13 10:05 AM
408strokerdart
Out West
I know that guy ..
Thanks Daryl, but that '64 is a work of art and no way my Dart was any nicer. Let me know if you ever make it back down this way and we will go out for a few "beverages" again.
#1521663
10/23/13 02:38 PM
10/23/13 02:38 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
So, I ask this to Brett.....Is there a chance at 5.0's with a max effort N/A SB build based around your current "big" port at 417 CID and still be a reliable bracket car? And I'm trimming weight again this winter....should be around 2740 race weight.
Great job....the car is flying.
"Max effort" and reliable bracket car are usually not found in the same sentence. Although if you get that car down in the 2700# range, a truely max effort W8 with a sheet, 2 x 4 and all the other ingredients will go well past 1000hp.
Might need a Proflite to run in the 5.0 range though....that is fast for an N/A straight headed smallblock at that weight, but I think Paul Ricci has run 8ohs at E-Town around 2800#.
[Re: jim sciortino]
#1521664
10/23/13 02:46 PM
10/23/13 02:46 PM
408strokerdart
Out West
I'm sure there are quicker out there, but parts to parts I think we are doing very well. These are 17 year old heads with a modern port and small cam, single 4bbl, small cast intake (and not the "good" one).
You are right Jim, reliable and max effort are different things which is why I'm torn over putting a big wedge in this or making this combo quicker at the cost of reliability.
#1521665
10/23/13 02:58 PM
10/23/13 02:58 PM
dartman366
Mt. Vernon, Ohio
Great job....the car is flying. I have erred on the side of reliability and let the car run what it runs, thats probably why mine don't run as well as others with a very similar combo but it's still together after 5 years of beating on it.
[Re: WHITEDART]
#1521667
10/23/13 08:34 PM
10/23/13 08:34 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Hauling the mail for sure.
I would have to do some digging but those numbers as good or better that Tim Davis was doing back in NSCA Hot street in 05'. Tim had the better intake. Set the NHRA record in B super modified. He also did a ton of developing and testing.
I was very displeased with my NA numbers 5.69 with a 2,950 race weight and a glide. Felt there was better numbers in the car like 5.40's. The 60 ft with the glide just would not cooperate.
What transmission are you running Brian? I would assume a Torqflite. Inquiring minds want to know.
Leon
