Re: Introduction and Looking For Some Advice
[Re: jingro]
#1521147
10/27/13 08:18 AM
10/27/13 08:18 AM
Posts: 1,534 AZ
Mike P
AZ
The transmission would work, but you would need the 6 Cylinder bellhousing, and I believe they also used a spacer plate. It would be cable shifted so you would also need to figure that out.
As light as the truck is I might consider using finding a 2 speed Powerflight rather than the 3 speed Torqueflight. The Powerflights were also air cooled (which would eliminate the need for cooling lines).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: jingro]
#1521150
10/28/13 11:46 AM
10/28/13 11:46 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Jingro, if you want a street rod then why not sell this one and buy one that has already been modified? If not then do whatever makes you happy with this one, these trucks are rare but even restored 100% the don't bring big money. This truck a 1937 is for sale right here on Moparts for 15K
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1521151
10/28/13 11:33 PM
10/28/13 11:33 PM
Posts: 10,863 Freeport IL USA
poorboy
Freeport IL USA
My Original or restored is OK if you only want to drive them in a parade. If you intend on driving it more often, or on the highways, a brake upgrade and a rear axle change is (or should be) the minimum standard. If you want add an automatic trans, upgrading to 12 volts is another logical step. If you have the space, keep the original stuff so you can later, or whoever gets it next can return it to stock if that is their thing. You're not planning anything that can't easily be undone. As far as value is concerned, mild upgrades like you considering will likely add value over stone stock for anyone except the hard core numbers guy. Most people are going to like the idea of getting something that looks old but can be driven any time they want. Personally, I'd change the wheels and tires too. Of the original gauges, everything except the fuel gauge is mechanical, voltage will not have any effect on them. The amp gauge will be showing a wider needle swing with 12 volts then it did with 6 volts, but should be OK. Change the gauge lighting to 12 volts or add a voltage reducer and take care of that fuel gauge and everything should be wonderful. Gene
[Re: poorboy]
#1521152
10/28/13 11:37 PM
10/28/13 11:37 PM
AZ_A12_BEE
Dreaming of the 808
That's exactly why I bought mine, looks old but has a more modern drivetrain with 12 volt conversion. This is a Dodge but this is the look I'm eventually shooting for, bad azz
37 Plymouth PU
[Re: dogdays]
#1521154
10/29/13 09:55 PM
10/29/13 09:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not that small, just old tech. Low compression, long stroke, soft crank that doesn't like high rpm, poor manifolding, valve in block flathead. But it makes good low end torque so if you added an OD to the existing trans it'd be better on the highway. If you got ambitious a small turbo with low boost would help, alot.
As for the OD, back int he 50's Chrysler had an optional OD unit that would bolt on to the existing three speed by replacing the tail shaft housing and other parts. If you could find one of those it would bolt up to the 37's, it's electrically operated.
[Re: jingro]
#1521156
11/07/13 03:50 AM
11/07/13 03:50 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Boy, those are a couple of nice looking trucks. Thanks for all the feedback guys. For now, I am going to leave it alone and enjoy it. I do see making it a driver in the future, but it is so cool like it is now, I hate to mess with it.
In the last couple of weeks I've had 3 guys want to buy it and had an old guy at Home Depot tell me all about the one he grew up with on his Dad's farm. He had me in the parking lot for 20 minutes looking it over and sitting in it. I was going to let him drive it, but his wife put an end to that idea. That's never happened with any of my muscle cars.
I just picked up a 1953 Plymouth station wagon, now maybe that one I could turn into a rod.
congrats on your free super hard to find plymouth truck,,some oen must be looking out for you,,,,,
that black 37/38 is sweet as well is the red street rod truck,,,and i dont even like red lol
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
