Need help with pilot bushing size #1520984
10/21/13 02:52 PM
10/21/13 02:52 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Engine is a 1969 340 with an A833 trans. Replacing things including the pilot bushing and the correct bushing for the motor appears to be P5007051.
I picked up one from my local parts store and it's larger than the one I pulled out of the car. No way it's going in.
Here are the dimensions of the used pilot bushing
OD 23.08mm
ID 19.08mm
Length 21.88mm
measurements of the new bushing
OD 23.97mm
ID 19.08mm
Length 22.08
ID is the same, both bushings seem to fit correctly over the input shaft, length is roughly the same.. OD appears to be the issue.
Can anyone verify part number and dimensions?
I can't imaging forcing the new one in due to the size difference.
Photo included of the new bushing not fitting into the caliper with the old bushing OD set...
Thanks,
-Rob
Re: Need help with pilot bushing size [Re: rkh17] #1520985
10/21/13 03:26 PM
10/21/13 03:26 PM
NAPA use to sell, probally still does, a adapter pilot bushing for Mopars tha had the smaller I.D. than the standard OEM crankshafts with the stock pilot bushings, it may be yours is one of those I've seen guys hone or bore out the back of the crankshaft on a automatic crank to make it a stick shift crank Shame on Moapr for making two different cranks Good luck on resolving this I don't speak metric so I have no idea what sizes you have, if I did I could go out in my shop and measure both of the those pilot bushings and see if the NAPA bushing is close to or the same as yours is
I'll be back on here later if you want to post the sizes in inches and I'll look at mine and let you know if that may be a option for you
Re: Need help with pilot bushing size [Re: rkh17] #1520986
10/21/13 04:10 PM
10/21/13 04:10 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is a common problem on big blocks but all my steel 340 cranks are drilled for the correct size pilot( the larger one). The easy fix is to use the later model one that comes in the new pickups. The fit in the back of the crank hub where the convertor hub goes. Don't get the ones with needle bearing but the one with the bushing.
Mopar created a big problem when they rough drilled the cranks for auto tranny and only finish drilled the ones for a std tranny.
Re: Need help with pilot bushing size [Re: rkh17] #1520987
10/21/13 04:14 PM
10/21/13 04:14 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I believe I had the same issue when I switched to a stick years ago in my f-body. I went with a late model roller bearing. It fits in the outside register for the flywheel. It's never been changed since. It was cheap & and the local NAPA carried it.
Re: Need help with pilot bushing size [Re: Cab_Burge] #1520988
10/21/13 04:18 PM
10/21/13 04:18 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
pushes the button to convert to inches..
Old bushing dimensions..
OD 0.908in
ID 0.751in
Length 0.861in
From looking at the new bushing I received from the parts store, I honesty think I'm looking at a different crankshaft. The car (1974 Challenger) does appear to have been converted to 4 speed from auto..
Thanks for your help and insights..
-R
RobH
72 Plymouth Duster 360
73 Dodge Charger SE 318
74 Dodge Challenger 340-4
74 Dodge Challenger 440
Re: Need help with pilot bushing size [Re: 80fbody] #1520989
10/21/13 04:18 PM
10/21/13 04:18 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I did the same thing when the bushing I bought would not fit the original 4sp crank. Went to the roller and it worked great!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Need help with pilot bushing size [Re: 80fbody] #1520990
10/21/13 04:49 PM
10/21/13 04:49 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Do you have a link to the late model roller bearing so I can take a peek?
Thanks,
-R
RobH
Re: Need help with pilot bushing size [Re: rkh17] #1520991
10/21/13 04:56 PM
10/21/13 04:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
These are the register-mounted pilot bushings/bearings. The NAPA 615-1033 undersized bushing is .915" OD.
Re: Need help with pilot bushing size [Re: rkh17] #1520992
10/21/13 05:00 PM
10/21/13 05:00 PM
scratchnfotraction Offline
Thanks,
-R
I just bought a new clutch set for a 93-5.2 NV4500 5 speed, the bronze bushing is the same as you have, on a 91-5.2 it is a little to big to just hammer in there. fits input shaft correct.
I orderd up a late model pilot bearing for the 93-d-250/NV4500
it fits in the bigger machined hole for the TC hub.
here it is for a part # referance and with it installed.
ran less than 18 bux at advance/auto
Re: Need help with pilot bushing size [Re: scratchnfotraction] #1520993
10/21/13 05:01 PM
10/21/13 05:01 PM
installed in the crank with flywheel bolted up
Re: Need help with pilot bushing size [Re: scratchnfotraction] #1520994
10/21/13 06:10 PM
10/21/13 06:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Just call a bearing supply place and tell them what you need. Its likely a stocked item and will cost you less than the Mopar part.
Re: Need help with pilot bushing size [Re: scratchnfotraction] #1520995
10/21/13 06:57 PM
10/21/13 06:57 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Thanks for all the tips. I think I'm just moving forward with the roller bearing... Looks like Brewers has one that will work.
http://www.brewersperformance.com/proddetail.asp?prod=PB5300&cat=16
RobH
