I Am Not Getting Fuel To My Six Pack #1520502
10/20/13 01:49 PM
10/20/13 01:49 PM
Pacific Grove, CA
black68gtx Offline OP
Pacific Grove, CA
I have been chasing down what I thought to be a vacuum leak in my 440 6 pack setup. In the process the fuel delivery to the carbs has become less and less until now I have no gas to the carbs.
I checked the split at the carb inlets and nothing. I found a filter just before the pump an disconnected it on the tank side. I was expecting a lot of fuel to come out but none.
After putting air into the gas tank I can get some to come out (but not as much as I would anticipate). I did replace the pump last night, but still no fuel.
1)I'll run a hose from the pump to an open container and see what I get.
2)I think that I could run a hose from a container of gas just before the pump and see what I get
3)I'll remove the filter on the tank & pump side then blow some air into the tank to check my flow.
4)I think would then check the fuel vapor lock separator to see if I have feul coming through it.
Anybody want to take a stab at this.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520503
10/20/13 01:59 PM
10/20/13 01:59 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Blow out the line from just before the pump to the tank pickup. Might be a plugged tank sending unit sock or maybe the pump pushrods or cam lobe is worn
Re: I Am Not Getting Fuel To My Six Pack [Re: ademon] #1520504
10/20/13 02:03 PM
10/20/13 02:03 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Re: I Am Not Getting Fuel To My Six Pack [Re: macmic87] #1520505
10/20/13 02:08 PM
10/20/13 02:08 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
just keep it simple and work on fuel flowing starting at the tank and working piece by piece to the engine. go step by step, don't jump from here to there trying to find the problem. fuel has got to be able to flow freely to the pump. mech pumps do not have a lot of suction. fuel must be able to get there and then the pump can do its job to push it to the carbs.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520506
10/20/13 02:31 PM
10/20/13 02:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
The pickup line in the tank is plugged, remove it and clean it out, put a new filter sock on it when done. If it is a 5/16 pickup don't fool with it, repplace it with a new 3/8 pickup and filter/ sock
Re: I Am Not Getting Fuel To My Six Pack [Re: Cab_Burge] #1520507
10/20/13 03:59 PM
10/20/13 03:59 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sometimes previous owners put an 'extra' filter in the line between the tank and the engine compartment. might check for one.
Re: I Am Not Getting Fuel To My Six Pack [Re: mikemee1331] #1520508
10/20/13 04:01 PM
10/20/13 04:01 PM
Pacific Grove, CA
Pacific Grove, CA
Yeah it does have an extra filter, between the tank and pump. I plan to remove it today.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520509
10/20/13 06:30 PM
10/20/13 06:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can't have a filter in front of the pump, only the strainer inside the tank should be used inside the tank before the pump. Take the filter out and connect on a long enough piece rubber hose onto the suction hose and blow through with your mouth first before using a air hose on it. That way you can tell if the strainer is clogged/restricted in the tank.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520510
10/20/13 08:48 PM
10/20/13 08:48 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
On the right track.....Start with the easy stuff first...You replaced the fuel pump....How did the fuel pump pushrod look ???
Re: I Am Not Getting Fuel To My Six Pack [Re: screamindriver] #1520511
10/21/13 08:23 AM
10/21/13 08:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
check the rubber line from the sending unit to the hard line. Take it off and check it, it could have some cracks or pin holes that are sucking air. AMHIK!
Coming soon!!!!
Re: I Am Not Getting Fuel To My Six Pack [Re: screamindriver] #1520512
10/21/13 01:53 PM
10/21/13 01:53 PM
Pacific Grove, CA
Pacific Grove, CA
All of the lines checked out. I found that the pump I put on from my 383 is not sucking so I went to put the original 440 pump on and found this.
Now that I have to replace the pump my questios are
1) What is the easiest way to install the pump (71 Challenger)
2) What makes the pump lever work the shaft in the engine must side up and down but what makes the shaft travel up and down?
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520513
10/21/13 02:10 PM
10/21/13 02:10 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
check this out: 440 FUEL PUMP
Re: I Am Not Getting Fuel To My Six Pack [Re: Golden-Arm] #1520514
10/21/13 03:42 PM
10/21/13 03:42 PM
Pacific Grove, CA
Pacific Grove, CA
That makes a lot of since.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520515
10/21/13 04:18 PM
10/21/13 04:18 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what is that orange thingy? is that something you put there to hold the rod up?
Re: I Am Not Getting Fuel To My Six Pack [Re: mikemee1331] #1520516
10/21/13 05:23 PM
10/21/13 05:23 PM
Pacific Grove, CA
Pacific Grove, CA
I think that's a finger applying the grease.
Re: I Am Not Getting Fuel To My Six Pack [Re: black68gtx] #1520517
10/21/13 06:10 PM
10/21/13 06:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
oopps, i thought that was your engine! oh yeah, to answer your questions - remove fuel lines to the pump, remove bolts holding pump to block, slowly so you can grab the rod that rides on the lever. installation is the reverse using the grease trick to hold the rod in the block until you get pump bolts started. question 2 - the rod travels agains the camshaft lobe.
Re: I Am Not Getting Fuel To My Six Pack [Re: mikemee1331] #1520518
10/21/13 06:39 PM
10/21/13 06:39 PM
Pacific Grove, CA
Pacific Grove, CA
I wished that I had asked this question before I spent so much time trying un-successfully install one.
