TF904 fitting size #1520390
10/20/13 11:40 AM
10/20/13 11:40 AM
South East VA
Joel71 Offline OP
Joel71  Offline OP
South East VA
What is the pipe thread size for the fittings that screw into the case that the hard lines attach to? '71 TF904.
Re: TF904 fitting size [Re: Joel71] #1520391
10/20/13 12:24 PM
10/20/13 12:24 PM
SE VA
hemibee69 Offline
hemibee69  Offline
SE VA
1/8" NPT is what I remember for the 904 and 727 Chrysler transmissions. If not correct there will be more responses I am sure.
JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: TF904 fitting size [Re: hemibee69] #1520392
10/20/13 12:36 PM
10/20/13 12:36 PM
South East VA
Joel71 Offline OP
Joel71  Offline OP
South East VA
Thanks for the reply. I swear it looks bigger but I'm not sure. Can someone confirm this? I want to go buy something for it before I take it out so I would like to have the size now. I suppose I could get both 1/8" and 1/4" to be on the safe side. Anyone know for sure?
Re: TF904 fitting size [Re: Joel71] #1520393
10/20/13 04:26 PM
10/20/13 04:26 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
1/8" NPT is correct unless somebody enlarged the case.
Re: TF904 fitting size [Re: John_Kunkel] #1520394
10/20/13 08:23 PM
10/20/13 08:23 PM
John I've been wondering about this, I've seen the brass fittings that are the next size up (1/4 NPT?) & use 3/8 inverted flare prefabbed brake lines. My Q is (with a 3/8 tube cooler) would all that give more flow for better cooling or are the passages inside the trans smaller than the fittings which that would be the limiting factor so that using larger lines etc outside would be a waste
Re: TF904 fitting size [Re: RapidRobert] #1520395
10/20/13 10:43 PM
10/20/13 10:43 PM
South East VA
Joel71 Offline OP
Joel71  Offline OP
South East VA
1/8" it is. I bought both to be sure. I thought for sure it was 1/4". The 1/8" does seem small even with 5/16" lines. All is fixed now, no more leak. This stopped me from spending a beautiful day at Budds Creek in MD for a full day of test & tune. Oh well, still have 3 more chances in Nov.
Thanks all for the info!
